InDesign crashes continuously when trying to export into PDF - Urgent Help!
Apr 7, 2012 12:50 AM
Hello All,
I'm facing the issue like InDesign is getting crashed continuously when trying to export directly the PDF, I'm using InDesign CS5.5. Please suggest urgently.
Praveen
    Apr 7, 2012 1:25 AM   in reply to Gejaraja
    Is your Indesign updated...?
    Apr 7, 2012 2:43 AM   in reply to Gejaraja
    Windows or Mac? If Mac, do you have a crash report? You can upload that to Pastebin.com, then put a link to it here.
    Apr 7, 2012 2:59 AM   in reply to Gejaraja
    What version? Do you get an error message?
    Does it crash if you make and use a new user account?
    Apr 7, 2012 3:13 AM   in reply to Gejaraja
    Windows 7 does not provide a lot of useful crash information, but any of the details from the crash dialog will help. Please make a new user account and try that. It will help to determine if the problem is in the program or your user.
    Are you running a script to do the export, or are you using File > Export...?
    Apr 7, 2012 3:27 AM   in reply to Gejaraja
    IS it happening with one particular document or all the document?
    have you tried with the new blank documnet?
    Please try File > Export from a new user account.
    And try a new file to be sure it isn't just file corruption.
  • John Hawkinson
    Jun 25, 2009
    Apr 7, 2012 8:52 PM   in reply to Gejaraja
    Gejaraja wrote:
    I tried with script, but later assumed it's crashing even doing manually using File -> Export.
    Sorry, that's terribly unclear.
    Is it crashing with BOTH the script and File > Export?
    Is your script using exportFile or asynchronousExportFile?
    If it crashes manually, have you tried disabling asynchronous exports per Re: Background PDF export Help?
    Apr 9, 2012 4:51 AM   in reply to Gejaraja
    Was the nested style in the text that was being picked up by the variable, or in the heading that included the variable?
    Apr 9, 2012 8:52 AM   in reply to Gejaraja
    I think that might be a bug. The variable is a single character, as far as ID is concerned, so formatting inside the text that is picked up should not make any difference.
    Aug 8, 2012 3:33 AM   in reply to Gejaraja
    I had the same thing happening and this worked for me:
    http://helpx.adobe.com/indesign/kb/indesign-crashes-blank-dialog-boxes .html
