I think I stumbled upon a bug in Flash Builder 4.6. I'm running FB on OSX 10.7 and I'm building native extension for OSX (AIR 3.1).
After successfull creation of my extension's native code .framework file in Xcode, writing Action Script wrapper around it and packaging everything together in ANE file (using adt) I discovered that I couldn't start a debug session from Flash Builder (4.6 and AIR 3.1). Since I was able to test my extension from terminal (using adl), I am pretty sure that I connected all the dots correctly.
I discovered that Flash Builder only before starting debug session unpacks the extension's .ane file into some temporary folder, beneath the workspace. Unfortunately, it messes the attributes of unpacked files so aliases are missing (they look like regular files) and main binary inside OSX's .framework package is missing executable attribute. Since those aliases and attributes are essential for things to work on OSX, FB simply fails to find extension and reports error like "ArgumentError: Error #3500: The extension context does not have a method with the name". Somebody else stumbled upon this in following post http://forums.adobe.com/message/3974973 (it seems it's specific to Linux and OSX, but not Windows - no aliasing there, huh?).
I would appreciate if somebody from Adobe could check that and verify if that's up to Flash Builder or not.
I think I found the problem (but not the solution)
When Flash builder launch adl, first extract the ane extension in a hidden folder:
~/Documents/Adobe Flash Builder 4.6/.metadata/.plugins/com.adobe.flexbuilder.project.ui/[folder for the project/macosx
Inside this folder there is a directory with the name of the ane (like myext.ane) and inside many files (catalog.xml, library.swf, META-INF, ...)
Inside META-INF/ANE/MacOS-x86/ there are the files of the OSX Framework with native code.
The problem is that the .framework folder is corrupter, the symlinks inside it are normal file (the contents is the path of linked file) but they are not real symlink!
So the problem is that the symlink inside the frameworks are not correctly generated.
If you start from flashbuilder the app without call code inside an ane, and (with the app opened) replace the broken file with the correct symlink the app works correctly also for the ane code!
I don't decompress manually the ane file for extract the correct symlinks, but replace the wrong file with the same from the framework folder make by xcode ![]()
Launching the debugger from flex and replace (before call any ane code) the symlinks allow to debug without any more problems.
I'm developing a little function that fix the framework symlinks to call when the app start (maybe using the conditional compilation so this code is use only in debugger mode and not in final release). The problem is that flex don't allow to create a symlink and for this function I need to call an external process (like a bash script)...
Late today I post the code...
this is the code that I develop to temporally fix the bug:
private static var
callback_error:Function = null,
callback_ioerror:Function = null,
callback_output:Function = null;
/** @param extensionID:String id of the ane extension to fix
* @param onExit:Function callback function with first arguments the value of extensionID and for the second the boolean state of the fix operation
private function fixANE(extensionID:String, onExit:Function=null):Boolean {
if (!NativeProcess.isSupported) {
if (onExit!=null)
onExit(extensionID, false);
return false;
// init event listners
if (callback_output==null)
callback_output =
function(event:ProgressEvent):void {
var process:NativeProcess = event.target as NativeProcess;
trace("OUT -", process.standardOutput.readUTFBytes(process.standardError.bytesAvailable));
if (callback_error==null)
callback_error =
trace("ERROR -", process.standardError.readUTFBytes(process.standardError.bytesAvailable));
if (callback_ioerror==null)
callback_ioerror =
function(event:IOErrorEvent):void {
trace(event.toString());
var ext_dir:File;
try {
ext_dir = ExtensionContext.getExtensionDirectory(extensionID);
} catch (e:*) {
if (onExit!=null)
return false;
if (!ext_dir.isDirectory) {
if (onExit!=null)
return false;
var ane_dir:File = ext_dir.resolvePath("META-INF/ANE/");
var ext_stream:FileStream = new FileStream();
ext_stream.open(ane_dir.resolvePath("extension.xml"), FileMode.READ);
var ext_xml:XML = XML(ext_stream.readUTFBytes(ext_stream.bytesAvailable));
ext_stream.close();
var defaultNS:Namespace = ext_xml.namespace("");
var framework:String = ext_xml.defaultNS::platforms.defaultNS::platform.(@name=="MacOS-x86").defaultNS::applicationDeployment.defaultNS::nativeLibrary.text();
if (!framework) {
if (onExit!=null)
return false;
var framework_dir:File = ane_dir.resolvePath('MacOS-x86/'+framework);
// list of symlink files
var symlink:Vector.<String> = new Vector.<String>(3, true);
symlink[0] = 'Resources';
symlink[1] = framework_dir.name.substr(0, framework_dir.name.length-framework_dir.extension.length-1);
symlink[2] = 'Versions/Current';
var fileToFix:int = symlink.length,
fileFixed:int = 0,
fileFailed:int = 0;
symlink.every(
function(item:String, index:int, a:Vector.<String>):Boolean {
var f:File = framework_dir.resolvePath(item);
if (!f.isSymbolicLink) {
var fs:FileStream = new FileStream();
fs.open(f, FileMode.READ);
var lnk:String = fs.readUTFBytes(fs.bytesAvailable);
fs.close();
var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
nativeProcessStartupInfo.executable = new File('/bin/ln');
nativeProcessStartupInfo.workingDirectory = f.parent;
nativeProcessStartupInfo.arguments = new Vector.<String>(3, true);
nativeProcessStartupInfo.arguments[0] = "-Fs";
nativeProcessStartupInfo.arguments[1] = lnk;
nativeProcessStartupInfo.arguments[2] = f.name;
var process:NativeProcess = new NativeProcess();
process.start(nativeProcessStartupInfo);
//process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, callback_output);
process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, callback_error);
process.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, callback_ioerror);
process.addEventListener(IOErrorEvent.STANDARD_ERROR_IO_ERROR, callback_ioerror);
NativeProcessExitEvent.EXIT,
function (event:NativeProcessExitEvent):void {
if (event.exitCode==0)
fileFixed++;
else
fileFailed++
if (fileFixed+fileFailed==fileToFix) {
if (fileFailed==0)
trace('ANE '+extensionID+' fixed.');
else
trace('Unable to fix ANE '+extensionID+'!');
if (onExit!=null)
onExit(extensionID, fileFailed==0);
} else
fileFixed++;
return true;
return true;
call this function passing the id of the extension and optionally a callback function:
function onFix(extensionID:String, success:Boolean):void {
if (success) {
// do the ane code...
fixANE("package.ANETest", onFix);
sbaldizz,
Just wanted to follow-up on your comment re: documentation for native extensions -
If you haven't already, you may want to check out: http://help.adobe.com/en_US/air/extensions/index.html. There's some deep-dive documentation out there about native extensions.
And for using native extensions with Flash Builder, you can see http://help.adobe.com/en_US/flex/mobileapps/WSe4e4b720da9dedb5-4aefe03 513238d8a1b8-8000.html.There are a few links in this article that can lead you to more information about using native extensions.
Hope this helps,
Mallika Yelandur
Adobe Community Help & Learning
There's another problem with the symlinks to watch out for. I built the framework then copied the directory over to the directory where I would build the ane from. I knew that by doing this the symlink files would still be pointing to the folders and files of the original framework folder that I copied, so I deleted the copied symlink files and remade them in Finder. Turns out that making these symlink files in Finder caused the files to not work. So instead of copying the framework folder I dragged it to where I would build the ane. I believe another way to do this would be to create the symlink files in terminal, though I haven't tried this. Hope this helps.
North America
Asia Pacific
