Folder hyperlink issue again - code reads differently in Reader than in Acrobat Pro
Apr 9, 2012 8:01 AM
So when I use Acrobat Pro, and paste a link to a server folder, the link works correctly. (I have to copy the folder link and then put "file:" in front of it to make it work, but it works).
For example, if I paste the text:
file:\\cgi\shares\Departments\Operations\Document Control,
a window opens up in Firefox and goes to:
file:///\\cgi/shares/Departments/Operations/Document Control
which is correct and shows the folder structure and available files to open.
However, when the same link is pasted into Acrobat Reader, the link comes up (after a couple of warning messages),
file:///shares/Departments/Operations/Document Control
which is not correct and only yields a blank page.
I need users to be able to open the server folder from Acrobat reader.
Using Windows 7, Firefox 11,0, LS 9.0, Acrobat Reader X 10.1.2.
Thoughts?
https://acrobat.com/#d=xEF1Y7dXFyiEbLkhfP3GZg
    Apr 12, 2012 1:43 AM   in reply to maestrodog1
    Your uri's all need to be safely encoded to be cross app/ corss platform ready. A safe path in adobe has different formatting than standard unc conventions, so if you enter \\cgi\\shares\Departments, you need to encode this as //cgi/shares/Departments and then add the file: notation in front. The safe path notation is not the same as a unc which you can use in browsers for example, it is just used to allow acrobat/reader api's a common format.
    When using paths like this in acrobat or reader all paths should be provided via script in a safe manner, so you should have file:///cgi/shares/Departments/Operations/Document Control even if the user enters something different.
    Mar 27, 2014 8:01 AM   in reply to maestrodog1
    From: http://forum.planetpdf.com/wb/default.asp?action=9&fid=101&read=63767
    This worked for me - make sure the new file created has no extension.
    Try this:
    - for each folder, temporarily rename the folder
    - next to the folder (i.e. in the parent folder of the renamed folder)
    create a file that has as its name exactly the original name of the
    folder to link to)
    - create you link using the Link tool in Acrobat
    - once done, delete the auxiliary file and rename the folder to its
    original name
    Worked for me using Acrobat 9 Pro.
    Olaf
