flex 4.1 sdk application issue
Apr 9, 2012 8:42 AM
My application consists of 4 modules developed in flex sdk 4.0, has resource bundles (eng and spanish), now we designed 5th module with flex sdk4.1 has eng and spanish resource bundles, when i
compile and run the whole app(5 modules) under unix environment with sdk4.0, every module is loading fine, until the 5th modules loads, when 5th module loads, for the first time spanish language is not
loading, the whole page is blank, when i switch back to english it is loading everything and then clicked spanish it is working fine, every time when i change the viewstack the spanish is not working for the
first time. I debugged the issue, it is not giving any error,
intialize() method is called, creationcomplete is not called for viewstack main component,
i changed all 5 modules to flex sdk4.1  and complied and it runs fine without spanish loading problem.
my question is their any way i can use use sdk4.0 and run the application,
is they any issue of developing one module with sdk4.1 and compling it with 4.0?
    Apr 9, 2012 2:19 PM   in reply to Rahul7777
    All modules and their loaders must be on the same version of the SDK.
    Apr 9, 2012 11:47 PM   in reply to Rahul7777
    Your first message said you had created the 5th module in a different SDK.  Which is it?
    Apr 10, 2012 11:00 AM   in reply to Rahul7777
    I think you will first have to figure out why it isn’t working.  What do you mean by “next pages loading blank”?  What is a page?  Does blank mean that nothing is drawn or just text?
    Apr 11, 2012 12:43 AM   in reply to Rahul7777
    I haven’t heard of something like this before.  You’ll probably just have to debug into it.
    Apr 11, 2012 9:39 AM   in reply to Rahul7777
    See if the constructor for any child component is getting called.
    What is in your “spanish mode”.  Just strings or different UI?
