Chris Campbell 9,456 posts
May 4, 2010
How do I fix Windows permission problems with Flash Player?
Nov 2, 2012 5:33 PM
Tags: #file #flash #permissions #player #folder #reboot #faq #registry
Occasionally users can encounter the following scenarios:
  • After installing Flash Player, everything works correctly until you reboot your computer.  After rebooting, web pages ask you to install Flash Player again.  This cycle continues over and over.
  • Flash Player works fine for administrator accounts, but Flash content is not available when logging in under a standard Windows account.
We're working on addressing these issues with our installers, but in the meantime these issues can be fixed using the following steps:
  1. Install Flash Player
  2. Download the SubInACL Installer from Microsoft
  3. Install SubInACL and note the install location
  4. Download the attached "reset_fp11.bat.zip" file and extract it to the SubInACL folder from the previous step.  At this point, subinacl.exe and reset_fp11.bat will be in the same folder.  Please note that you might not see the file extensions unless you've made them visible.
  5. If you are on Vista or Windows 7, right click "reset_fp11.bat" and select "Run as Administrator".  If you are on XP, please make sure you are using an Administrator level account before double clicking.
  6. You'll see a window appear and text go by, this should only take a few seconds to complete.
  7. If you were unable to install Flash Player in step 1, do so now.
  8. Restart your computer and verify that Flash is working correctly.
