Lightroom LR4 - Silly RAM usage!!
Apr 9, 2012 5:18 PM
Tags: #lightroom #- #ram #lr4 #silly #usage!!
  Latest reply: 1234ewqrd, Jul 16, 2012 5:27 AM
    Apr 20, 2012 11:37 PM   in reply to GKN 100
    Move to 64 bit.
    Apr 21, 2012 4:46 PM   in reply to Dorin Nicolaescu-Musteață
    And of course are you advising buying an infinite amount of memory in addition to the new hardware to deal with a software bug?
    Jul 2, 2012 9:48 PM   in reply to John Spacey
    John
    I tried successfully your negative caching steps.  So far there has been a very decided improvement.  Since each of my raws are 24+ mps every time I touched one I would watch the ram usage climb in task manager/ process/ lightroom.  If I worked on the image using the adjustment tools every stroke increased the ram usage.  I was often well in excess of 6 gb and then if I round tripped to PS for my Nik filters or any other addtional adjustment PS also wouldn't release memory.  As others have complained LR would either freeze for a period of time or become extremely slow.  While I haven't figured out how to release the PS ram your negative caching has help immensely in LR.
    Question - why on earth isn't this part of the code?
    Do you know a way to release the same memory problems in CS5?
    Bob
    Jul 3, 2012 4:39 AM   in reply to John Spacey
    Thanks for the details re negative caching - it has worked a treat - seems like a totally different piece of software now - I don't have to restart LR after editing 3-4 images! It had an earth-shattering effect ...... Lightroom started to run fast, and then immediately I then had to endure a 7.0 earthquake!!
    I also saw this post ....http://photocamel.com/forum/computers-software/162752-help-lightroom-4 -1-slow-performance-problems.html which discusses the issue of corrupted preference files and offers a solution
    Jul 16, 2012 5:27 AM   in reply to John Spacey
    Hi John,
    I tried the negative cache lua file, and so far as I can tell, it has evened out the performance. I don't seem to be getting a slowdown when doing spot, brush, grads etc.
    My normal raw file is from a D90 and I even tried messing with a D800 NEF I'd downloaded. Although it was slower (I've just got a dual core 2.6ghz with 8gb ram) it went acceptably.
    How on earth did you find out about that fix?
    Interestingly (or not, I suppose it depends on your level of interest), i was looking at the Windows performance monitor and I saw that the CPU went to about 50% even when I was simply moving the cursor around the image. That was the same with any size nef file.
    My memory has remained fairly stable (I believe some have seen what appears to be memory leak behaviour).
    I'd tried all other fixes offered in the forum.
    with thanks,
    Hans
