If those additional <b> tags in the output would not be there, everything would be ok. And those tags are definitely added by RH. I do nothing else than writing the content in RH and when finished I press the button for webhelp generation. I think, I write a bug report.
Of course I could delete all <b> tags from the output files - hoping that there are no other <b> tags that are necessary somewhere. This workaround takes time: I have ca. 50 files, 6 languages and 3 variations for each language.
Which machines are mentioned by google? I'm working with Windows 7. Last year I was working with Windows XP and there I did not have this problem.
I am not arguing that you are doing anything with the code or denying that RoboHelp is adding the <b> tag. You are saying "If those additional <b> tags in the output would not be there, everything would be ok." My point was to edit those tags out of the output file to see if all is then OK. From what I am reading you are saying they are the cause but I am not clear whether that is theory on your part or that you have proved it.
Enter "Direct2D/DirectWrite hardware acceleration" into Google and see the first link. That suggests to me the setting will only affect machines with certain hardware.
You are doing better than I would in whatever your first language is. ![]()
In Design View I created two paragraphs to start with and applied Bold to the first sentence and a single word, the to the whole second paragraph.
Where there are closing span tags, in the output you will get the extra <b> tags that are causing your problem. You will note there is no closing span tag in the second paragraph and no <b> tag gets written in the output.
<p><span style="font-weight: bold;">This is some sample text.</span> This
is some sample text. This is some sample text. This is some sample text.
This is some sample text. This is some sample text. This is some sample
text. This is some sample text. This is some sample text. This is some
sample text. This is some sample <span style="font-weight: bold;">text</span>.</p>
<p style="font-weight: bold;">This is some sample text. This is some sample
sample text. This is some sample text. This is some sample text. This
This is some sample text.</p>
Then I hit Enter and clicked the bold icon to return to normal weight and got this crazy HTML.
<p style="font-weight: bold;"><span style="font-weight: normal;">Sample
text added later.</span></p>
I have reported this as a bug.
Meantime try this. In Tools > Options there is an option Convert RoboHelp edited topics to HTML. Tick that and see if it makes a difference. It will apply to all projects.
Does that help?
In that case the only option I see for now is Willam's script suggestion.
Sorry.
Interesting, so Danny wasn't the only one with this problem.
Thanks for posting a solution Mike.
Please anyone affected by this bug, submit a bug report.
The more people who report a bug or request a feature, the more likely it is to be actioned. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
North America
Asia Pacific
