Udates were downloaded, installation started and then received:
Error 1321. The installer has insufficient privileges to modify the file C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\plug_ins\Multimedia\MPP\QuickTime.FRA.
My system is Windows 7 professional up-to-date as of today. I don't use Quicktime and certainly not its French version.
As per the error, it seems to be a permission specific issue.
Try giving full permissions to the "C:\Program Files (x86)\Adobe\Acrobat 10.0" and "C:\Program Files (x86)\Common Files\Adobe\Acrobat".
You can check the below article for hot to apply permissions on Win 7.
https://help-internal.adobe.com/content/help/en/creative-suite/kb/erro r-1321-or-1309-install.html
Also, try disabling the startup items.
http://helpx.adobe.com/x-productkb/global/disable-startup-items-servic es-windows.html
Turn off User Account Control as well.
http://helpx.adobe.com/x-productkb/global/disable-user-account-control -uac.html
Thanks, Arpit, for your reply.
Your statement about permissions, some problems that I was having with other applications, and the fact that I was having all these problems after installing the "second-Tuesday-of-th-month" Windows Update made me investigate more deeply.
It turns out that the user account that I used orginally to install Acrobat X -- even though it is defined as an "Administrator" account -- does not have access any longer to the directory config.msi.
When I signed on to the USERID "Administrator" I was able to update Acrobat X normally and I was able to solve my other application problems as well.
It appears that an user-defined Administrator account is no longer the same as the account "Administrator".
Thanks again. This problem is solved.
North America
Asia Pacific
