Hi there,
I have an HP desktop that I’ve edited two feature films on, the first shot on the HVX200 (edited with CS4) and the second shot on the Canon 5D (edited with CS5). About to edit a new feature, shot at 4K on the Red Scarlet, using CS5.5.
I THINK I know what needs to happen here, but basically, at anything higher than 1/8 resolution, the footage is playing back slow, and then, when I synch up with my .wav sound files, the sound is dropping out after a second (unless I scale to frame in the timeline only, in which case the render bar goes from red to yellow and the sound remains, even if the picture is still choppy). Basically married image and sound will not play back properly unrendered.
So, I guess what I’m asking is: does this sound like a RAM issue? Should I go for 16? I currently have 8. There’s a lot going on on this computer. (Specs are below.)
One final question, albeit a more minor one: why does the frame Fit properly in the Source Monitor but need a Scale to Fit instruction every time to fill the Project Monitor? Is there a way to make an entire Sequence Scale to Fit permanently?
Again, my computer specs are below.
Thanks!
Stephen
HP Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
918 GB
8.0 GB Physical Memory
Microsoft Windows Vista Home Premium Edition (64-bit)
Service Pack 2
ATI Radeon HD 4850 (recently updated)
512 MB Memory (since updated to CS5.5 specifications)
Hi, Harm-
Thank you for the response. Just wanted to point out that even as is, I'm successfully able to sync sound and view the footage at 1/8ths resolution (and, as of last night, some clips are able to play without being rendered), I would just like to more smoothly and efficiently navigate picture and sound at at least 1/4 resolution, and not have the sound drop out. I also just a year and a half ago edited a 1080 DSLR feature on this system with no issues.
I trust your advice, but if what I'm lacking adds up to more than just RAM, what is it about the system that's insufficient?
Stephen
Hi there,
I appreciate all of the help. Currently trying to pick a new system, needing to keep it under $1200 or so. How does this look for cutting RED 4K footage? http://www.mwave.com/mwave/SKUSearch.asp?px=FO&scriteria=BE02420
One concern is the NVIDIA GeForce 530. Will that cut it, and if not, what's the best way to upgrade? Seems to be the consistent card amongst desktops in this price range.
Thanks!
Stephen
You'd probably want to upgrade to Windows Professional, and at least double that 8Gb to 16 (go with 32 if you can swing it).
You don't need a 1TB system drive, as you'll only be using it for Windows and Programs. You can easily get away with 250GB or even smaller, so that may save a little money. But, you will need to add at least two more hard drives, (Projects/Scratch and media). Those can be 1TB or more. (And using tapeless RED media, you'll want some kind of backup for your media. An external maybe.
If you're working with RED footage, you'll probably want a Blu-ray burner, not just DVD.
The nVidia 530 might work if it has enough memory (1GB min.).
Thanks, Jim. Excuse my naivete, but what do you mean by two more hard drives? I've edited two features on my old system (including a 1080 DSLR feature), and am even viewing footage/syching sound with the RED 4K on the same old system (original stats listed at the very top) just fine. I guess I'm a bit surprised that such leaps are recommended, when I'm working with the same footage on my 4-year old system as it stands now.
But I'll do what it takes, obviously. Lastly, any recommendations for places that will customize to my needs?
Thanks so much,
Stephen
There is still not enough ram in the listed PC, and the 530 is a poor choice. Nvidia list the memory type as DDR3, where you want a card with DDR5. You can get a suitable system for close to the price that is listed. You want to look at Harms hardware guide, and likely shop a custom builder.
You want
CoreI7 or high end I5
Minimum 12 gb memory for HD editing
Minimum 2 physical drives (system & media)
gtx card with at least 1gb ddr5 memory.( I would shop for more memory for 4K footage ) The more CUDA core, the better.
I spent a little more than you or I really wanted to spend on my CS5.5 box $1400 However it works brilliantly.
Core I5 2500k
16gb memory
2x 74GB 10K raptor drives raid0 system drives
2TB media drive
GTX 560Ti 1GB with 384 CUDA cores.
You could shave this system down to under $1k for something that works great.
The GTX555 seems like the base level card to me. A GT or lower spec card might be a gamble.
Look at gamer machine builders rather than prebuilt desktops. They let you choose parts. That is where to start shopping.
And not having a very good time of it, right? Isn't that why you're here?
The advice is not meant to make things "work", but to make them work well (or at least bearably).
In any edit system, three drives is what I consider an acceptable minimum. More is better, but I feel three is the starting point for decent performance.
Point very well taken, Jim. You're absolutely right.
Stephen, thanks for those specs. If there's an answer to this, what is an example of something I could shave to get the price down a little, without large risk?
I'm brand new to customizing systems: any recommendations for reliable and trusted companies I can call/visit to build my system? I'm in Los Angeles, but I imagine this could be done over the phone as well.
You guys have been great.
Thanks!
Stephen
Try seeing what Eric or Scott at ADK can do for you.They are master NLE builders and absolutely great support.
North America
Asia Pacific
