kierankelly
Question on Skewing Path Strokes
Apr 10, 2012 9:56 PM
Tags: #illustrator #cs5 #effects #path #stroke
HI there,
I'm a longtime Illustrator user and have a general query on Skewing Paths...
Essentially this is to do with creating logotypes, see below - the issue is when I skew a path with a stroke the end points 'tilt round' or stay as they were - to get round this i must outline the Path forst, which is fine, but makes editing post skewing alot harder....
I appreciate this might be somewhat esoteric - but any tips would be greatly appreciated
Thanks in advance
K
    Apr 10, 2012 11:22 PM   in reply to kierankelly
    Esoteric questions are the best kind.  There's no wrong answer. ;-)
    It's not as precise, but you could Effect->Outline Stroke and then Effect->Distort & Transform->Free Distort
    Alternately - Effect->Outline Stroke and then Object->Envelope Distort->make with mesh...  1x1, skew as usual.
    Apr 11, 2012 2:29 AM   in reply to kierankelly
    You could also make a symbol and then skew the instance of the symbol. You won't need a mesh
    Apr 11, 2012 4:30 AM   in reply to kierankelly
    That might also just be another instance of the Align to Pixel Grid issue.
    Have you turned that option on or off (see Transform palette)?
    Apr 11, 2012 5:13 AM   in reply to kierankelly
    You're welcome, kierankelly
    Apr 11, 2012 11:42 AM   in reply to kierankelly
    Probably I'm a bit muzzy at the moment, but am I the only one who says that example 2 inside the initial post shows just an atypical behaviour when it comes to skewing/shearing stroked paths?
    No workaround, like using meshes or symbols, should be necessary here.
    Apr 11, 2012 11:52 AM   in reply to Kurt Gold
    Skewing doesn't affect the caps of open stroked paths. Never has done.
    I think we would have hellish trouble on our hands if it did.
    How would we go about un-skewing it again if it had been, say, manually rotated or otherwise edited?
    Apr 11, 2012 12:08 PM   in reply to Steve Fairbairn
    I see. I misinterpret the original screenshot. Thought the letters would consist of filled paths, each surrounded by a stroke.
    Obviously a wrong assumption.
    Apr 11, 2012 7:16 PM   in reply to kierankelly
    Since we're talking about letter forms here (and logotype, at that), I hope you realize that skewing a stroked path versus skewing an unstroked filled path (or a Symbol Instance containing just open stroked paths) does not result in the same thickness of the vertical stems:
    This is one reason why italic (or even oblique) versions of typefaces are not merely skewed versions of the regulars.
    JET
