Save as PDF file as excel file or text file in vba excel
Apr 10, 2012 11:10 PM
Hi all,
I am opening a PDF document fromm VBA excel. After opening document it should save the document as excel file or text file in one folder.
I am trying to do this with some code but not able to , pls help me thatnks.
Dim AcroApp As Acrobat.CAcroApp
  Dim Part1Document As Acrobat.CAcroPDDoc
Set Part1Document = CreateObject("AcroExch.PDDoc")
   Part1Document.Open ("Z:\EG MI Information\MIS\Requests\Req_156\NO.1.pdf")
  Dim app As Object, avdoc As Object, pageview As Object
Set app = CreateObject("AcroExch.App")
Set avdoc = app.GetActiveDoc
app.MenuItemExecute ("SaveAs")
thanks
Abhijeet
    Apr 11, 2012 3:50 AM   in reply to Abhijeet4
    You want to look at the JSObject (which connects JavaScript to COM/OLE/VBA) and then the this.saveAs() method in JavaScript.
    Apr 12, 2012 2:14 AM   in reply to Abhijeet4
    Usage of the JSObject is shown in the VB Samples folder in the Acrobat SDK in this folder
    [Acrobat SDK Install location]\Version 1\InterAppCommunicationSupport\VBSamples
    and look in these two samples to see how to use the JSObject
    JSObjectAccessVB
    JSOFindWordVB
    There is also documentation on the JSObject here
    http://livedocs.adobe.com/acrobat_sdk/10/Acrobat10_HTMLHelp/IAC_DevApp _OLE_Support.100.18.html
    http://livedocs.adobe.com/acrobat_sdk/10/Acrobat10_HTMLHelp/IAC_DevApp _OLE_Support.100.13.html
    Hope this helps
    Malcolm
    Apr 12, 2012 6:32 AM   in reply to Abhijeet4
    In the documentation for the saveAs function it has the following params
    cPath The device-independent path in which to save the file.
    cConvID (optional, Acrobat 6.0) A conversion ID string that specifies the conversion
    file type.
    cFS (optional, Acrobat 7.0) A string that specifies the source file system name.
    bCopy (optional, Acrobat 7.0) A Boolean value which, if true, saves the PDF file
    as a copy. The default is false.
    bPromptToOverwrite (optional, Acrobat 7.0) A Boolean value which, if true, prompts the user if
    the destination file already exists. The default is false.
    In order to get a text file saved you need to specify the correct cConvID.
    See the documentation for the valid convID's - http://livedocs.adobe.com/acrobat_sdk/10/Acrobat10_HTMLHelp/JS_API_Acr oJS.88.519.html
    Please note the Acrobat SDK contains all the information and does not require much installing ( as it is a zip file(on windows) and a disc image (on Mac) it just needs extracted)
    Regards
    Malcolm
    Apr 12, 2012 7:29 AM   in reply to Abhijeet4
    The cConvID was added in Acrobat 6.0 and later so it would need work, as you are seeing, in Acrobat 5.0
    Regards
    Malcolm
    Apr 12, 2012 8:01 AM   in reply to Abhijeet4
    No, that functionality is not available in that EXTREMELY OLD version.
    Also, even if you were using Acrobat 7, we could not help you as we no longer support that version either.
    You need to upgrade to Acrobat 9.
    Apr 13, 2012 2:05 AM   in reply to Abhijeet4
    HI,
    The Adobe Reader software can only save files if they have been enabled by the LiveCycle Reader Extension's Server or Acrobat Professional, if you have an enabled PDF file then the script should work, although please note the documentation which says.
    Note: This method can only be executed during a batch or console event. See Privileged versus
    non-privileged context for details. The event object contains a discussion of JavaScript events.
    Please see the documentation for more information
    Malcolm
    Apr 13, 2012 3:43 AM   in reply to Abhijeet4
    No, Adobe Reader does not support COM/VBA for automation.
