galoot3346
Set default import format when drag and drop sound file into multitrack view?
Apr 11, 2012 1:39 PM
Tags: #import #default #drag_and_drop #audition_3
I've looked around the preference panels but cannot find where to set the import settings for dragging and dropping sound files into multitrack view. Some of our computers have correct settings and others do not. Thanks for your help!
G
    Apr 11, 2012 2:48 PM   in reply to galoot3346
    Audition imports all audio files as .wav whether you open them in Edit or Multitrack view. How do the settings appear to differ in your computers?
    Apr 12, 2012 10:45 AM   in reply to galoot3346
    The bit depth and rate is set for a newly opened session by what is saved as the Default session. This can be accessed from the File menu Default Session. You can save your current session as the Default from there. So make sure that all your settings are correct and then save the current session as default. You should thus be able to get all PCs the same. Hope that helps.
