Form Fields Printing but Not Form Itself?
Apr 11, 2012 12:29 PM
We have a fill-able form. When printing, the form fields print out fine but the form itself will not print. We realized it was a secured pdf, and contacting the original sender, was able to unsecure it. It prints out form and the text form fields.
Some time has passed and a part of the form is no longer applicable to us. Using Acrobat Livecycle, we deleted that part, but now, when we try to print, we have our initial problem of the form fields printing but not the form itself. And contacting the original sender is not an option.
What is causing this? How can we make it so that it prints out the form and form fields? Should we be suing a different program to edit the pdf? (And for my own knowlegde, how do you do something like that in the first place?)
Thank you so much.
  • George Johnson
    Aug 11, 2002
    Apr 11, 2012 12:57 PM   in reply to elegantdecay
    It's really hard to tell without looking at the PDF in question. Editing it with LiveCycle Designer would be appropriate if the form is an XFA form that was originally created in Designer, but not if it's an Acroform, which are normally created in Acrobat. There are a number of reasons that only the fields are printing, but without looking at the document, I can't say for sure.
    Apr 13, 2012 6:13 AM   in reply to elegantdecay
    As George mentioned, it is difficult to find out what's wrong without looking at the PDF. So, kindly share across the PDF form.
    Also, how did you created the PDF??? On what OS and with which Acrobat version???
