Having an issue with the eraser tool.
Apr 11, 2012 4:14 PM
Tags: #cs5 #help #photoshop_cs5 #eraser
Hello All,
I am quite new to photoshop, so thank you in advance for your patience.
When I use the eraser, I get a black line outlining the path that the eraser took.
Here, I drew a square, then erased a path through the top and left side. I now have two discrete, closed sections. I intended to get a clean erasure resulting in a two-line shape in the upper left, and a four sided, open shape in the rest of the image. Basically, I want it so they are not closed shapes.
And advice? Thanks.
    Apr 11, 2012 5:14 PM   in reply to teach_me_how_to_erase
    Welcome to the forum.
    I think you are doing something different than you think you are.
    To check open a new document (file/new).  Draw a black square with the paint brush then erase a section as above.  Think you will just see erased section.
    Do you have eraser in brush mode (box in eraser tool bar)?
    Do you really have a white canvas with a black line?
  • Noel Carboni
    Dec 23, 2006
    Apr 11, 2012 5:58 PM   in reply to teach_me_how_to_erase
    I'm thinking you are erasing pixels on a layer that has a Stroke layer style.  Stroke means that wherever the layer borders between visible pixels and complete transparency there will be a line drawn.
    -Noel
    Apr 11, 2012 7:50 PM   in reply to teach_me_how_to_erase
    If it's indeed what Noel suspects (stroke layer style) then you could add a layer mask, set in the Blending Options>Layer Mask Hides Effects
    and paint on the layer mask with the brush tool set to black (the foreground color in the toolbox).
    Apr 12, 2012 9:32 PM   in reply to teach_me_how_to_erase
    You can use the rectangular marquee tool to draw a square and then go to Edit>Stroke, but you loose the ability of easily changing  your edits.
    You could also save a layer style and use that with shape layers (or any layer), but you would still have to add a layer mask unless you recorded an action.
