LindaWhaley
Slide Manager Go To setting ignored after publishing
Apr 11, 2012 8:36 PM
Tags: #navigation #to #skip #presenter #go
I have a PPT that has slides I want skipped unless the user clicks on a hyperlink to access them.  I skip over these slides in the slide manager by setting the go to slide to the one after the slide to be skipped.  I also do not want any timings set so I have the PPT controls set to manual and the Presenter settings set so that none of the playback options are set and the slide timing is O.O.  After I publish the PPT the  large play button correctly cycles forward through the PPT skipping the slides I want skipped.  If the user instead uses the |< or the >| arrow keys it will cycle through each slide including the ones I want skipped. It also cycles through all the slides if the user decides to use the up or down arrow. [Edited: The latest published version does not advance on the user selecting the up or down arrow key from the keyboard until the presentation has been gone through one time] Is there a way to control the navigation better?
Thanks.
Linda
    Apr 15, 2012 8:54 PM   in reply to LindaWhaley
    Hi Linda
    This is as it has been designed in Presenter.
    The |< or the >| will only move the user on the the previous and the next slide.
    The only way you can do this is disable the playbar and provide branching through hyperlinks in the presentation.
    But if you want the playbar and the TOC to be there then I think it will not work the way you wanted
    the only workaround for your problem is to provide hyperlinks to the entire presentation and remove the playbar and the TOC
    Mahesh Nayak
    Apr 16, 2012 8:10 PM   in reply to LindaWhaley
    Hi Linda
    Do the following
    1. Go to the published folder
    2. Go inside the data folder
    3. Open the vconfig.xml in a notepad
    4. search for "playbar". It should be under the UIshow tag
         <uishow name="playbar" value="true"/>
    5. change the value to false and run the presentation
    thanks
