All fields work great except the submit button... Why ? But works great on my iMac using acrobat 8.0.
My form is saved like this... PDF(complete document)
My submit button... mailto:alfagra@rocler.qc.ca
Like I said the only thing that does not work correctly in my form is the submit button.
Text fields and check box fields work great.
Also my submit button works great on my computer (iMac) and all other computers I have tested (including PC)
using acrobat reader 6.0 and above.
Thank you for your time !
That /should/ work. Would it be possible to share your form via email to pawibbel@adobe.com? Thank you!
We have identified the cause of the issue. It looks like there is an optional parameter in the PDF specification specifying the "File System" for the submit. That parameter should be set to "URL" if present. If it's not present, the Reader should treat it as URL by default. Unfortunately, we are treating it as a required parameter and in this case it has been ommitted. I have filed a bug and I believe we can get to this in a coming release. Please look for updates. I'm also investigating to see if there is a way we can help you re-author the form so that it can be submitted in the interim. Thank you again for reporting this issue and sharing the file.
Pat
jamboncult,
The fix for the submit button issue will be included in our next release. Please see the list of issues addressed here:
http://blogs.adobe.com/readermobile/2012/04/30/adobe-reader-patch-upda te-10-2-1/
You'll note that it links back to this forum thread which means you were the first to report it. Thanks!
Pat
North America
Asia Pacific
