wrap a 2D image around a round surface
Apr 12, 2012 2:06 AM
I have an image of a 2D  image ( sky and cloud). I want to use it in a 3D scene.To cover the back I would need to paste this image on a round surface so you dont see the corners of the image when moving the camera.
Can you do this in After Effects cs 5.5?
/Mattias
    Apr 12, 2012 2:14 AM   in reply to mattias@gordon.se
    CC Cylinder or CC Sphere. Set the render mode to inside only, make them huge.
    Mylenium
    Apr 12, 2012 5:57 AM   in reply to mattias@gordon.se
    Yes.  Both plugins respond to the After Effects camera in 3D space, so you can position your camera "inside" the Sphere or Cylinder.  But note Mylenium's advice to set it to render "Inside Only".
    Alternately, you can break your background into segments and orient them so you have a series of flat planes instead of a true curve, which often works well enough.
    Or, investigate Trapcode Horizon.
