mdnavaz
How to modify the code to get started the timer on mentioned time?
Apr 12, 2012 3:50 AM
I have the following code from a source. I would like to make a few changes as mentioned below:
First ....
1) The as3 code should get the time form "startMeeting_txt.text"
2) Compare it with current time from "currentTime_txt.text"
3) The Timer should be activated as soon as the "startMeeting_txt.text" = "currentTime_txt.text" and starts counting
4) When the "finishMeeting_txt.text" = "currentTime_txt.text" then
5) "message_txt.text" = "Meeting time is over"
How to modify the following code:
var count:Number = 60;
var myTimer:Timer = new Timer(1000,count);
myTimer.addEventListener(TimerEvent.TIMER, countdown);
myTimer.start();
function countdown(event:TimerEvent):void {
myText_txt.text = String((count)-myTimer.currentCount);
if(myText_txt.text == "0"){
      gotoAndStop(2)
Thanks.
    Apr 12, 2012 4:39 AM   in reply to mdnavaz
    You should show an attempt to do this yourself so that your wishlist of what happens when makes better sense.
