Static function parameter help
Apr 12, 2012 11:07 AM
I have two functions in the same file, how can I use the first function as default value in the second function.
public static function get decimalFormatter1():NumberFormatter{
I try this:
public static function secondFunction(param1:String, param2:Int=0, param3:Function=decimalFormatter1):Array{
Getting error: -1047: Parameter initializer unknown or is not a compile-time constant.
Any ideas?
Thanks!
    Apr 12, 2012 12:32 PM   in reply to jfb00
    decimalFormatter1 is a getter, so when you write the parameter
        param3:Function = decimalFormatter
    the default value is the result of calling the getter (i.e., it is the NumberFormatter returned by the getter); it isn't a Function. There is no way to treat a getter or setter as a Function object.
    Gordon Smith, Adobe
    Apr 12, 2012 12:34 PM   in reply to GordonSmith
    As a workaround, you could use null as a default value, where null means "use decimalFormatter1". You'd write something like
    public static function secondFunction(param1:String, param2:int = 0, param3:Function = null):Array
        var formatter:Function = null;
        if (param3 == null)
            formatter = decimalFormatter1;
