Can't finish previewing. There isn't enough memory. ID = -108
Apr 12, 2012 1:13 PM
Tags: #illustrator #problem #cs5 #error #memory #pdf #adobe #pc #cpu #ram #-108 #isn't_enough_memory #can't_finish_previewing #id_=_-108
We run CS5.
One of our clients sent us a file that they would like printed.  The file is 1MB in size, and in PDF format - nothing unusual about any of this.  As usual, I saved the file and tried to open it in Illustrator to set up a proof for our customer, and to check and make sure the file is print-ready.  I received the error: "Can't finish previewing.  There isn't enough memory. ID = -108".  I press OK and it opens up a blank file with some crop marks on it.
I've tried finding a solution online, but everyone who has this problem seems to have next to no RAM.  I'm running on a brand new computer with Windows 7, 16GB of RAM and the Intel Core i7 processor.  I didn't think my RAM or cache were the problem, but just to be sure, I shut off the computer, let it sit for a few minutes, and started it up again.  Same problem.
I am able to open the file in Photoshop and Acrobat - but even when I save the file at a lower resolution, and turn it into a jpeg, it still won't open.  I get the same error.
I need to be able to work with this file.  How can I resolve this?
Thanks!
    Apr 12, 2012 2:23 PM   in reply to Josh.AGI
    Josh,
    What happens if you create a new document and then try to File>Place the troublesome file in it?
    Can you provide that file for inspection?
    Apr 12, 2012 2:24 PM   in reply to Josh.AGI
    Josh,
    Can you share the file publically? If so, upload it to dropbox.com and provide a link.
    If it cannot be shared publically, and you would still like someone to look at the file, you can contact me through the PM and I can provide my email.
    Take care, Mike
    Apr 12, 2012 3:05 PM   in reply to Josh.AGI
    Josh,
    I'm curious to find out why this was happening though.
    File corruption may be the cause. Placing the file strips it of some wrapping which may be the corrupt part.
    When I click the link, I get what seems to be just an HTML page in the browser.
    Apr 12, 2012 10:13 PM   in reply to Josh.AGI
    Hi Josh--I was out the remainder of the day and evening.
    I don't know whether you have gotten to the bottom of the problem yet. The PDF seems to just consist of an image. It opens and places fine here in everything I have that can do so.
    There doesn't seem to be anything extrodinary about the file. It included crop marks, but as far as I can see, there's nothing way out on the artboard, etc., that could indicate there was something weird.
    If you would like a file, I can ZIP an AI file and the extracted image--which you can also do from Acrobat as well.
    Take care, Mike
