Hello! I'm a new user to Premiere and am having some problems importing DSLR video (5Dmk3 24p). I've done a lot of searching and have found a few people with similar problems, but I wasn't able to work through figuring it out. So now I'm consulting the best of the best. ![]()
My problems: (note: when I say crash, I mean hangs indefinitely. I've never seen an error message through any of this.)
Video of the problem: (pardon my poor TV persona
My computer: Intel i5, Windows 7 65bit, 16gb RAM, 60GB SSD HD, 1.5TB storage SSD. Premiere is updated (5.5.0 233), I have all the computer/driver updates that I know of.
I've tried reinstalling Quicktime (several times) and also reinstalling Premiere. I've tried changing the scratch disk, the Adobe CS agent said I should import files one by one and from the desktop but to no avail. A work around that kind of works is to import a few files, save, import, save, etc., so that when Premiere crashes, I can keep importing where I left off.
This problem is really bugging me and I would so appreciate it if any of you have some wisdom to share.
I read online where someone had a similar problem and ended up reencoding to a different codec as a workaround, but I would rather not have to do that. Thanks you!
SSD for storage MAY be your problem...
SSD and Video Editing http://forums.adobe.com/thread/902915?tstart=0
Hmm...that's interesting. That wouldn't be the problem since my SSD is only a few months old though? Also my project file, scratch disk (which I guess isn't used having 16GB ram), and video files are on a normal HD.
My only guess is that it's all Quicktime's fault and that this is a conspiracy of Apple to make crappy Windows software to try to make people switch. ![]()
We've seen some cases where files from the 5D MKIII do not import properly. (The MKIII was released after CS5.5, and uses a different format from the 5D MKII) As a workaround, you can rename the file extension (you can automate this through Adobe Bridge if you have a lot of clips) from .MOV to .MP4. This will cause Premiere Pro to process the files with a different import module that will handle the file correctly.
Wow wow wow it works! I thought I tried this but I guess not. It was a painful experience but I now know a ton more about troubleshooting Premiere, how codecs work, and am a slightly higher level geek. Thank you so much! This is so much better than reencoding. ![]()
I'm super happy to hear this...but I have one quick question: will this be fixed with an update? I just bought CS5 (from CS2) and probably won't upgrade for another ~5 years.
I can live with this though, I'm just curious. =)
North America
Asia Pacific
