Klindse704
Adding GREP search to FindChangeByList script in CS4
Apr 12, 2012 7:34 PM
Tags: #cs4 #scripting #grep #indesign_cs4
I'm trying to remove numbers from a baseball box score pulled from the Internet.
The file has 10 numbers across separated by tabs and I only need six of the numbers not all 10
St. Lucie Mets
Player,Pos         AB     R     H     2B     3B     HR     RBI     BB     SO     AVG
Daniel Muno, 2B    4     1     1     0     0     1     1     0     2     .259
Robbie Shields, DH     4     0     2     1     0     0     0     0     1     .471
This GREP search works in FindChange in InCopy/InDesign (using CS4)
(\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d)
This works in the Change field
$1 $2 $3 $7 $8 $9
However, when I try to add this to a FindChangeByList script, it generates an error. So my syntax, logic or both is flawed.
What should I do to fix it?
grep    {findWhat:"(\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d)"}    {changeTo:"$1 $2 $3 $7 $8 $9"}    {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false} Find all double spaces and replace with single spaces.
Thank you,
Keith
    Apr 13, 2012 1:36 AM   in reply to Klindse704
    Try again with all your single backslashes changed to double backslashes.
    .. I just checked the sample file; apparently, the only commands in there with backslashes are the ones that happen to not require them double. A Bad Example.
