ForumCruiser 23 posts
Dec 13, 2011
Playback freezes in PrE10
Apr 13, 2012 12:50 AM
I have big problems with my PrE and playback of my video files. I edit a large number of short (1-5min) videos. When I import the video file, the "Conforming video" process seemingly runs fine but when I start playback (clicking play or using space bar) in the Preview window the playback hangs on the first frame. I can step through the video with J/L or the arrow keys but there is no sound. When this happens, the video does play in an external player such as Windows media player. I have seen similar questions in the Forum but no solutions.
I can bring the video down to the timeline, step back and forth and perform all edit operations but the video still does not play. There is also a green dot in the video thumbnail in the project window. There are no other color markings or lines.
This is a very frequent but sporadic problem. For each video I start a new project. Sometimes it appears immediately after starting PrE and sometimes in the second/third or tenth project and sometimes I can work the entire half a day without a problem. It does not matter if I have only PrE started on my computer or if other applications are started or in which order they are started. When the problem appears the only way to get PrE to run again is to log out from Windows and log back in again. This is really getting to be a nuance.
I would really appreciate any help on this.
Hardware:
HP EliteBook 8440p Intel Core i5 M520 @ 2.40GHz, Dual core/4 threads
4.00 (3.80) GB Ram, 64 bit Windows 7 Enterprise SP1
Intel HD Graphics driver 8.15.10.2509
PrE is installed locally on the C: partition but my projects and video files are located at the corporate server on a 1Gb wired network.
The video files
I use a Canon XA10, “talking head” disposition and overexposed white background.
AVCHD video in “mts” format @ 1920x1080, 25fps, 256kbps 2ch stereo @48kHz
The project files
Premiere Elements v10.0(20110902.Mol11.B123.280463)
PAL-AVCHD-Full HD 1080i 25
Thanks in advance!
    Apr 13, 2012 8:05 AM   in reply to ForumCruiser
    When you Import those AVCHD files into PrE, and place them onto the Timeline, is there a red line above them, initially?
    If there is no red line, then your Project settings are correct, but if not, then you need to investigate the your Project's setting.
    When you get red lines above your Clips, say when you add an Effect, any form of overly, or Transitions, to get the best playback, you will want to hit the Enter key to Render the Timeline. However, with AVCHD, or any H.264 material, your i5 will never likely give really smooth playback, this is just too much necessary processing needed.
    Also, it appears that you have but one physical HDD, and then have it partitioned. What is the speed, and size, of that HDD? Partitions will slow down the process also. See this ARTICLE.
    I see two immediate problems: the i5 and the partitions, and there could be more, such as a mis-match between the footage and the Project, and possibly the speed of your HDD. For laptops, they are commonly 5400RPM, and 7200RPM is the minimum for smooth video editing.
    Good luck, and let us know a bit more.
