applefan6
Serial number not working, not disk doesn't work (mac copy)
Apr 13, 2012 1:44 AM
I've just brought a new Mac Mini installed my Photoshop CS3 onto it. When I opened the application my serial number wouldn't work because I've used it too many times. My last computer crashed, so I can't take Photoshop off it. I followed a tutorial which had two options:
1. reset the clock on your computer uninstall and re-install.
2. delete the following folders in /Library/Application Support/Adobe: Adobe PCD, backup and caps. And re-install
Now when I try to install Photoshop CS3 it doesn't even install! There is a cross instead of a tick next to everything. I've tried repair disk in Disk Utilities, and I was told that there was nothing wrong with the CD.
Is there a way to fix this?
    Apr 13, 2012 1:58 AM   in reply to applefan6
    For the best assistance, I recommend our chat support at http://adobe.ly/yxj0t6. Our chat representatives can provide a personalized experience to resolve the issue you have described.
    Apr 13, 2012 2:14 AM   in reply to applefan6
    Now you are not even able to install the software and gettingthe red cross as soon as enter your serial number.
    hence follow this step:-
    1)  Run the cleaner tool for CS3 , www.adobe.com/support/contact/cscleanertool.html
    2) delete the files ;- /Library/Application Support/Adobe: Adobe PCD, backup and caps
    3) Re-install the software ,
    let us know if the software gets installed ,
    Apr 13, 2012 4:32 AM   in reply to applefan6
    This has to be resetted by Adobe only...hence this is the chat link which will help you contact Adobe support ,
    Just let them know what happened and they will reset the activation count.
    chat link:- http://adobe.ly/yxj0t6
    Apr 13, 2012 4:44 AM   in reply to applefan6
    Sure....No problem.....Hopefully everything will be fine and you will be able to use your photoshop
