• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Error Help..
Community Beginner ,
Apr 13, 2012 Apr 13, 2012
TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at AttackMC/frame25()
what do ii do?
What does this mean?
if ii put ...
stop();
trace("parent: " + parent);
trace("mc parent: " + MovieClip(parent));
MovieClip(parent).gotoAndPlay(MovieClip(parent).currentFrame+1);
to trace it out the following comes out...
parent: null
mc parent: null
____
so..
ii am using Flash player 10
how do ii give it a parent.. so that it works..
In the library the movieclip is called Attack and then their is a linkage AttackMC
is that the problem?
TOPICS
ActionScript
Views
599
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I am going to guess that you removed the line addChild(Attack) from your code from earlier.  You originally said you added that to make it play, but that is not what it does,  What it does is adds it to the stage so that it then has a parent (the main timeline).  If you do not use the addChild() command, the movieclip will still play if you tell it to, and without a parent it will fail with the error you are getting.
Votes
Translate
Translate
Report
Report
objectMove.addEventListener(Event.ENTER_FRAME, testHit);
function testHit(event:Event):void
          var Attack:AttackMC = new AttackMC();
          if (objectMove.hitTestObject(objectWall))
                    objectMove.removeEventListener(Event.ENTER_FRAME, testHit);
                    addChild(Attack);
that what you mean?
Thats on the maintimeline and then the Attack is a movieclip in the library
And that is the coding for the Attack movieclip
import flash.display.MovieClip;
stop();
Votes
Translate
Translate
Report
Report
LEGEND ,
It is as I suggested.
With that line where it is you are likely creating hundreds of those AttackMC objects before you actually generate a hitTest.  But the only one that gets the addChild() working for it is the one that gets added when the hitTest passes.
So the first of the hundreds that you create  that plays to its end will produce the error you are getting since it was never added to the stage.
You do not want to be instantiating new instances every time that function gets called, and that function gets called at the frame rate of your file.  Just put a trace command in right after that line and see how many of those you end up creating before your hitTest finds a hit.
You should declare that outside of the function and instantiate it only once inside the conditional.
Votes
Translate
Translate
Report
Report
ii get over a couple of screen full of them..
do ii just move it or recode it?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
I already answered that in the last sentence of my last response.  You can do a little bit of both.  What you should do is think about what you need to do with it.  Where you have that line now you can see what it does.  You only want to create one when you need it.
I feel people learn from working things thru rather than being handed solutions, so that why I am not handing you the code that would fix it.  It is a simple change, involving a simple concept that you should get under your belt.  working thru it will help.
Votes
Translate
Translate
Report
Report
