Is there a way to select multiple contours after using "live trace"?
Apr 13, 2012 11:44 AM
I am using "live trace" "make and expand" command in order to post-process images.
This generates multiple path contours. In order to select a path I know that I have to “ungroup” the art object. This allows me to select one path, or even two using the shift key. However I am not able to select more than two paths (as a matter of fact I am trying to select 10 paths).
Is there a solution for selecting more than 2 paths after “live trace”?
Thank you for help.
    Apr 13, 2012 12:01 PM   in reply to AVIsar*
    I dont think that there is any such limitation on selection of object after live trace , may be you haven't ungrouped properly ....
    1) edit--> select All
    2) object-->ungroup
    and then check
    Apr 14, 2012 8:16 AM   in reply to AVIsar*
    If you having difficulties selecting the paths on the canvas try selecting them in the Layers Panel using the shift key as well.
    U
