source-path mismatch problem
Apr 13, 2012 12:58 PM
I'm trying to integrate unit testing with our build process and failing with the following error message.
BUILD FAILED
C:\Projects\project\client\FUTest\build.xml:88: Compilation failed: Warning: Source path entry, 'C:\Projects\project\client\FUTest\src\tests', is a subdirectory of source path entry, 'C:\Projects\project\client\FUTest\src'.
C:\Projects\project\client\FUTest\src\tests\SampleCase.as: Error: A file found in a source-path must have the same package structure '', as the definition's package, 'tests'.
C:\Projects\project\client\FUTest\src\tests\SampleSuite.as: Error: A file found in a source-path must have the same package structure '', as the definition's package, 'tests'.
I realize that my project structure does not match the sampleCIProject but I'm trying to fit this into an existing project that also does not match.
Here's the structure
FUTest/src/main/FlexUnitApplication.as
package main
     public class FlexUnitApplication extends Sprite
          public function FlexUnitApplication()
               onCreationComplete();
          private function onCreationComplete():void
               var testRunner:FlexUnitTestRunnerUIAS=new FlexUnitTestRunnerUIAS();
               testRunner.portNumber=8765;
               this.addChild(testRunner);
               testRunner.runWithFlexUnit4Runner(currentRunTestSuite(), "FUTest");
          public function currentRunTestSuite():Array
               var testsToRun:Array = new Array();
               testsToRun.push(Request.methods(SampleCase,["simpleAdd"]));
               return testsToRun;
FUTest/src/main/FlexUnitCompilerAppliaction.as
package main
     import flash.display.Sprite;
     import tests.SampleCase;
     import tests.SampleSuite;
     public class FlexUnitCompilerApplication extends Sprite
          private var tests_SampleCase_obj:SampleCase;
          private var tests_SampleSuite_obj:SampleSuite;
FUTest/src/test/SampleSuite.as
package tests
     [Suite]
     [RunWith("org.flexunit.runners.Suite")]
     public class SampleSuite
          public var t1:SampleCase;
FUTest/src/test/SampleCase.as
package tests
     import flexunit.framework.Assert;
     public class SampleCase
          [Test(description="My First Actionscript Unit Test")]
          public function simpleAdd():void
               var x:int = 5 + 3;
               Assert.assertEquals( 8, x );
FUTest/build.xml
<?xml version="1.0" ?>
<project name="flex unit test" default="info">
    <property file="build.properties" />
    <taskdef resource="flexTasks.tasks" classpath="${FLEX_SDK_DIR}/flexTasks.jar" />
    <target name="info" description="flex unit test">
        <tstamp />
        <echo message="============================================"/>
        <echo message="flex unit test"/>
    </target>
    <!-- GLOBAL SETTINGS -->
    <property name="FLEX_HOME" value="${FLEX_SDK_DIR}/${FLEX_COMPILER_VERS}" />
    <property name="EXT_LIBS" value="../ExternalLibraries" />
    <taskdef resource="flexUnitTasks.tasks">
        <classpath>
            <fileset dir="${EXT_LIBS}">
                <include name="flexUnitTasks*.jar" />
            </fileset>
        </classpath>
    </taskdef>
    <!-- PROJECT SETTINGS -->
    <property name="FU_TEST" value="FUTest" />
    <property name="SRC_FU_TEST" value="${basedir}/src" />
    <property name="OUT_FU_TEST" value="${basedir}/bin/FUTest.swf" />
    <property name="TEST_DIR" value="${basedir}/src/tests" />
    <property name="OUTPUT_DIR" value="${basedir}/target" />
    <property name="BIN_DIR" value="${OUTPUT_DIR}/bin" />
    <property name="REPORT_DIR" value="${OUTPUT_DIR}/report" />
    <property name="DIST_DIR" value="${OUTPUT_DIR}/dist" />
    <target name="compile" description="Build the FU Test Project" depends="init">
        <echo message="Compiling..." />
        <exec executable="${FLEX_HOME}/${MXMLC}" failonerror="true">
            <arg line="-compiler.include-libraries=${EXT_LIBS}/flexunit-4.1.0-8-as3_4.1.0.16076.swc" />
            <arg line="-compiler.include-libraries=${EXT_LIBS}/hamcrest-as3-flex-1.1.3.swc" />
            <arg line="-compiler.include-libraries=${EXT_LIBS}/flexunitextendedAS.swc" />
            <arg line="-compiler.include-libraries=${EXT_LIBS}/FlexUnitTestRunner_rb.swc" />
            <arg line="-compiler.incremental=true" />
            <arg line="-debug=${debug}" />
            <arg line="-default-background-color=${background.color}" />
            <arg line="-default-frame-rate=${framerate}" />
            <arg line="-default-size ${width} ${height}" />
            <arg line="-source-path='${SRC_FU_TEST}'" />
            <arg line="'${SRC_FU_TEST}/FUTest.as'" />
            <arg line="-o=${OUT_FU_TEST}" />
            <arg line="-use-network=true" />
            <arg line="-static-link-runtime-shared-libraries=true" />
        </exec>
    </target>
    <target name="init">
        <!-- Create directories needed for the build process -->
        <mkdir dir="${OUTPUT_DIR}" />
        <mkdir dir="${BIN_DIR}" />
        <mkdir dir="${REPORT_DIR}" />
        <mkdir dir="${DIST_DIR}" />
    </target>
    <target name="test" depends="compile">
        <echo message="Running Tests..." />
        <!-- Execute FlexUnit tests and publish reports -->
        <flexunit
         workingDir="${BIN_DIR}"
         toDir="${REPORT_DIR}"
         haltonfailure="false"
         verbose="true"
         localTrusted="true">
            <source dir="${SRC_FU_TEST}" />
            <testSource dir="${TEST_DIR}">
                <include name="**/*.as" />
            </testSource>
            <library dir="${EXT_LIBS}" />
        </flexunit>
        <!-- Generate readable JUnit-style reports -->
        <junitreport todir="${REPORT_DIR}">
            <fileset dir="${REPORT_DIR}">
                <include name="TEST-*.xml" />
            </fileset>
            <report format="frames" todir="${REPORT_DIR}/html" />
        </junitreport>
    </target>
</project>
The initial complile seems works fine and produes bin/FUTest.swf.  So why does the flexunit compile fail?
Any help most appreciated.
- mlindsay
