Tinestram
Having trouble with drawWithQuality
Apr 14, 2012 3:18 PM
Tags: #air_3.3 #drawwithquality
Using Flash CS5.5 with the SDK overlay. drawWithQuality comes up in code view no problem and it compiles fine, but at runtime I get:
"ReferenceError: Error #1069: Property drawWithQuality not found on flash.display.BitmapData and there is no default value."
Any ideas would be appreciated!
    Apr 19, 2012 5:06 PM   in reply to Tinestram
    publishing for swf version 15?
    Apr 19, 2012 6:37 PM   in reply to cnuuja
    I am getting the same issue with flash cs5.5
    tried swf version 15 and 16 with 3.3 sdk and these overlay instructions http://www.flashdeveloper.co/post/20583114199/air32-in-flash-cs-55
    ADL:
        at Untitled_fla::MainTimeline/frame1()[Untitled_fla.MainTimeline::frame1 :8]
        at runtime::ContentPlayer/loadInitialContent()
        at runtime::ContentPlayer/playRawContent()
        at runtime::ContentPlayer/playContent()
        at runtime::AppRunner/run()
        at ADLAppEntry/run()
        at global/runtime::ADLEntry()
    android device (3.3 runtime installed):
        at AppEntryCommon/run()
        at global/runtime::AndroidMobileDeviceAppEntry()
    Apr 20, 2012 9:02 AM   in reply to 1901rob
    Did you set the namespace to 3.3 in application xml?
    Apr 20, 2012 11:48 AM   in reply to Tinestram
    Please make sure that SWF version is 16, and namespace is set to 3.3. Did you replace airglobal.swc with the one found in AIR SDK 3.3?
    Apr 20, 2012 11:22 PM   in reply to Tanya Parkhomovsky
    Ok, well it works now!
    Error on my part I suppose.
    swf version 16, 3.3 namespace, airglobal.swc replaced, it was showing the code hints, but not compiling. Same with the new BMD.encode()
    I simply deleted the Air 2.6 folder and did the procedure again and it works now.
    Maybe something was write protected and didn't copy over the first time when replacing the AIR2.6 folder, or maybe I made a mistake somewhere.
    Thanks for your help, and a great feature!!!
