Jay55O
Pin registered
Apr 14, 2012 6:44 PM
I am using Kelby's PSE 7 book. On page 83-86 he covers pin registered. I think his directions leave out an important step since after quite a few trys, I can not get it. Can anyone give me the sequence of steps to do it?Thank you very much. Jay
    Apr 14, 2012 9:15 PM   in reply to Jay55O
    That usually refers to moving a layer of the same pixel dimensions to another document of the same pixel dimensions by using the
    move tool, dragging the layer to the other document, holding down the shft key before releasing the mouse button.
    If the documents are not of the same pixel dimensions, then holding the shift key just centers the layer.
    It might be good if you were to mention what version of elements your using.
    Apr 14, 2012 9:00 PM   in reply to Jay55O
    Example of moving a layer from one document to another dragging from the layers panel (you don't have to use the move tool):
    Example of using the move tool to move a layer from from one document window to another:
    Apr 15, 2012 9:51 AM   in reply to Jay55O
    If your trying to put two copies of the same camera raw file into the same document, i would open the first photo.
    Then go to File>Place and navigate to that same photo (the camera raw dialog will open again) and press okay
    and you'll get the same photo, processed differently if desired on two seperate layers.
    Apr 27, 2013 12:43 PM   in reply to Jay55O
    Hi Jay 550
    did you ever manage to find out what bit of the instructions are missing?
    I have PS Elements 11 and the Scott Kelby Elements 11 book and am hitting exactly the same problem as you describe. I have been impressed with the book so far as this is the first problem I have hit (pages 87 - 88 in this version)
    Apr 30, 2013 1:22 AM   in reply to Jay55O
    Jay - Thanks for the contact  - I have sent Cindy an e-mail but not heard from her yet
    May 2, 2013 2:40 AM   in reply to Chris1512
    Now sorted.
    With Cindy's Help I found out that I had (somehow) changed the default setting for the depth pop up menu in Camera Raw - from 8 bits to 16. This is at middle bottom of the Camera Raw screen.
    Apparently everything in the book assumes default setting.Other filters also do not work at 16 bits so if a filter is greyed out that is a likely reason
