MrFixMe
Menu issues
Apr 14, 2012 11:17 PM
Hey guys.
I am trying to figure out why all my menus open when I put the mouse over the root item in the menu. How can I fix this? Thank you in advance.
misterfixme.com
  • Liam Dilley
    Feb 28, 2012
    Apr 14, 2012 11:38 PM   in reply to MrFixMe
    Hi there.
    Could you provide more information please or a link tot the site?
    What dynamic menu version are you using?
    Are you using the default or CSS HTML only version?
    Your issue could be incorect JavaScript or CSS etc.
  • Liam Dilley
    Feb 28, 2012
    Apr 15, 2012 8:36 PM   in reply to MrFixMe
    Your main Navigation Menu has no sub items under any of those links such as Shop.
    You have a second menu which is the Mobile one in the bar which has sub navigation links which seem to work fine in firefox.
    If you intended this to be under one of the main navigation links above you need to add it as a child of one of those menu items.
    Another thing I noted is you have your Search form HTML in there twice sitting on top of each other.
  • Liam Dilley
    Feb 28, 2012
    Apr 16, 2012 12:41 AM   in reply to MrFixMe
    Ok, with you.
    You need to polish up more of your CSS further.
    Because you have the hover and you have a ul inside the li it is treating that and the second ul li inside it.
    There is a zip file here: http://forums.adobe.com/docs/DOC-1903 Which is of a menu system, pure css I did. I think if you download that and look it has sub menu's etc you can have a look at the CSS and see how it is all working. It was built with how BC outputs menu's in mind so you should find it useful.
