Hello,
I originally posted this in the 'Downloading, Installing, Setting Up > Discussions' forum and have been sent here to see if anyone may be able to help; I need some advice and guidence on buying a new laptop that will run Creative Suite 5 Design Premium. I have a desktop which I use for the majority of my design work, but I need something portable for tweaking and presenting whilst on the move.
The key thing is I need it to be lightweight as I have joint problems so preferably under 1.9kg (I know that usually the smaller then the less powerful) and with a good as possible battery life. I mainly use Photoshop, Illustrator and some InDesign, working to real size (usually under and up to A3, sometimes larger)
I've found two possibilities; can anyone guide me if either of these will run comfortably for what I need?
Featuring Genuine Windows® 7 Home Premium (64-bit)
2nd generation Intel® Core™ i3-2330M processor
4GB memory for top system performance
500 GB Hard Drive for storing all your digital files
35.5 cm (14.0") High-Definition LED-backlit BrightView Display
Intel® HD Graphics
Finished in Dark Umber, Brushed Aluminum
1 year, pick-up and return, warranty. Optional upgrade to 3 years accidental damage cover for peace of mind
Featuring Wi-Fi, Bluetooth, Integrated Webcam & Microphone
Includes HP Entry Carrying Case & HP Wireless Mobile Mouse
Sony VAIO VPCSB4C5E (VAIO SB 13 series) £614
Configured
Intel®Core(TM)i5-2450M,2.50GHz
320 GB Serial ATA (5400 rpm)
DVD disc drive
8 GB 1333 MHz DDR3-SDRAM
33.7 cm LCD, 1366x768+webcam
No Wireless WAN
No Long-Life Battery
No security features
HD digital camera
Office 2010 Starter + Acrobat
No protection
McAfee Online Backup trial
No Imagination Studio Suite
Also Included
Backlight keyboard
AMD Radeon(TM) HD 6470M 512MB
English (QWERTY)
1 AC Adapter
USB 2.0 x2 + USB 3.0 x1
Wireless LAN (802.11abgn)
HDMI(TM) output
Bluetooth® 3.0
If the HP one will run the suite ok then I'll go for that one, as a little kinder on the budget. I've compared them myself but I'm not sure if the HP would be sufficient or if the sony would be wasting money when somethign cheaper will do the job? Though at the moment Sony are doing a deal for 8gb RAM for the inclusive price of 4gb, but only until Monday...
Any advice would be really appreciated, thank you!
Go to HP's web site and you can customize the laptop to your needs and keep an eye on the cost as you add/subtract features. The thing to keep in mind is, forget about tech support, plan on paying someone local to fix it, or fix it yourself or buy new. As Tech support is no good in my eyes.
For me the price out weights the tech support other wise I would pick someone else.
If you need good tech support, then well, not much out there, maybe Dell, but I have seen laptops that break under normal or almost normal wear and tear. Their laptops must be sent in, but I guess tech support is OK. Never owned a Dell laptop, just seen friends with them.
I have heard rumors of bad tech support from Sony, but thats just rumors, so I can't say how good or bad they really are.
As for a lighter laptop, you could go with a solid state hard drive, they don't hold as much, but they are faster and much lighter than their counter parts.
Get as much ram as you can afford, you will be glad you did, when the time comes. I have already ran out of ram editing a video with 16 GB of ram, so you never have enough.
Anyway, good luck on your purchase, I am sure, you will enjoy it, which ever decision you make.
Thank you Silkrooster. I'm in England and the customisable features aren't on the UK HP website unfortuantely (the American site's much better to be honest). I'm not too concerned about tech support as there are local companies to us.
If you don't mind me asking, in your opinion would the Sony one in my original post suffice if I upgraded to the'128 GB SATA Flash SSD(1 x 128 GB) Solid State Drive' and use an external drive to store my work? Thanks
With a solid state drive, you may be able to go with a slimmer case on the laptop. Which would or should lighten the laptop. As long as you have an external drive that can hold your data, you should be fine with 128GB drive. But if you afford it go next size bigger. In the long run, it should pay. But with the external it isn't as necessary.
But I don't know all the uses you will have for the laptop. As you add programs, games, pictures, video's etc. it fills up quickly. It would be up to you on what needs to be on the internal drive and what can go on the external. Later on, you may want a second external just for back up purposes. When you loose your data, you will be glad you have a spare drive with the data.
Anyway, good luck...
North America
Asia Pacific
