Output timeline to HDMI monitor
Apr 15, 2012 12:21 AM
Hi
I am using PPRO CS 5.5 on PC and looking to upgrade to CS 6 when it comes out.
I would like to get an output to an HDMI monitor, and would probably need a card for that.
I have seen several cards on the web, but kind of unsure, which to chose. I only need preview output; no input.
Thanks.
Ulf
    Apr 15, 2012 12:38 AM   in reply to UlfLaursen
    Every modern day video card can output to two monitors, AMD Eyefinity cards even up to 6 monitors and the nVidia GTX 680 up to 4 monitors.
    So if you only use a single monitor and want to add a second monitor, you probably only need the correct cable. If you use dual monitors and want to add a third monitor, then your choices are limited to the 680 or an AMD, or two GTX 4xx or two GTX 5xx cards that use the same driver.
