I have form and I need to send form in PDF format to specific mail ...
in the start user must select check box :
when user select 1 check box option subject mail is Name 1 + address2 ....
when user select 2 check box option subject mail is Name 2 + address2....
My problems (sorry I'm beginner), is button for send form in the PDF format ...
I create one button for each subform like (click event) :
--------------- subform1 -----------------
var oDoc = event.target;
oDoc.mailDoc(
bUI: true,
cTo: "a@b.com",
cSubject: form1.page1.subform1.Name1.rawValue + " " + form1.page1.subform1.address1.rawValue
------------------ subform2 -----------
oDoc.mailDoc(
bUI: true,
cTo: "a@b.com",
cSubject: form1.page1.subform2.Name2.rawValue + " " + form1.page1.subform2.address2.rawValue
But that work only for option 1.
When select on then check box option 2 and press button - don't work.
Can i set one button for all form (and where put it) , where mail subject will be value from actual subform , and format form="pdf" ?
Thanks ...
Views
Total Likes
I have solution :
in each subform create a Button (Object -> Field -> Control type -> Regular) with click event :
var vSubject;
var vCC="";
var vBody="";
var vEmail="a@b.com";
// Create subject from subform field :
vSubject = first_name.rawValue + " " + last_name.rawValue + " - born : " + born_date.rawValue ;
event.target.submitForm({cURL:"mailto: "+ vEmail +"?subject=" + vSubject +"&body=" + vBody + vCC,cSubmitAs:"PDF",cCharset:"utf-8"});
Views
Total Likes
