ifok83
Expression number generator
Apr 15, 2012 4:14 PM
New to expressions
What I have so far I have this is the text source
Math.round(random(100).toFixed(2))
Which gives me randomly generated numbers without a decimal
What I need
Fixed characters right after those numbers
The numbers to stop on a set value at a set moment
Also how would I do a countdown (instead of random) and adjust the speed of it.
    Apr 15, 2012 10:14 PM   in reply to ifok83
    You could just tie your math round function to a slider and a multiplier. It should be very easy to figure out. Then just animate the slider.
    V = slider value;  (pickwhip to the expression slider)
    Math.round(V)
    Apr 15, 2012 10:42 PM   in reply to ifok83
    You sound confusing. Does you countdown need to have any randomness? If not, Dan's solution would be as simple as it gets. If you need randomness, you could still use it and simply add your randomness, but you'd need a second slider for the randomness intensity, so you can stop it when you need to...
    Mylenium
    Apr 17, 2012 3:01 AM   in reply to ifok83
    Basics of JavaScript - string concatenation. Anything additioanl goes in quotation marks and is added:
    Math.round(V)+"%"
    Mylenium
