P_Flamenco
Having problems with Indsign CS5 - install onto 2nd machine successful - But..
Apr 15, 2012 7:33 PM
But indesign won't open any files - going into an endless spiral of not responding?? I have installed and re-installed twice to no avail.. ; Photoshop & Illustrator all good ( First installed version of same license on laptop is not open during the second install process as described in installing on second machine single user?? what is happening? Brand new imac 27" top spec with the power but can't run with it on indesign.... hopefully just a little issue that can be resovled easily?? Thanks for any advice....
    Apr 17, 2012 4:27 AM   in reply to P_Flamenco
    • #  Quit InDesign (force quit, if necessary).
    • #  Move the following folder to the desktop:
      Mac OS: [Startup Disk]/Library/Applications Support/Adobe/SING/
    • Note: This is in the Library folder on the root of your startup disk. There is a similar path in your user folder, but that is not the path you need to work in.
    • Relaunch InDesign.
