Hello all,
Is it possible to find and replace a combination of character formats.
for example:
Search for VA. The V in Arial and the A is Helvetica.
Replace this in V Arial and A in Verdana.
Regards.
Ive been thinking about this, and I don't think it's possible. It certainly isn't doable in one step in Find/Change and I don't think it's doable at all because there is not, as far as I know, a way to use a lookahead or lookbehind to find formatting that is different from the formatting of the string you are trying to locate, and you can't find multiple formats in one step.
You can certainly find a V followed by an A, and you can even find all Arial V followed by A, or Helvetica A preceded by V, but unless the formatting is restricted to JUST the VA combinations you are looking for you have a problem. If you can fiund just those combinations, you could replace using formatted contents of the clipboard, but I don't see a way to be sure you are only finding the particular string you want.
It might be scriptable, though...
Create a new swatch and call it "Red".
Find V in Arial, replace with character color "Red".
Find A in Helvetica, replace with character color "Red".
Replace "VA" in character color "Red" with something else (from the clipboard is fine).
Delete swatch "Red" and replace with Black.
A lot of work, certainly, but then again the OP seems to be mixing Arial, Helvetica and Verdana at will, so I guess that's the price to pay.
NutTriooo wrote:
Hello all,
for example:
Regards.
If the letter pairs are always the same, change one manually, then copy to clipboard. Find whatever; in the change to pop-up menu under the "@" symbol, Other > Clipboard Contents Formatted.
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
North America
Asia Pacific
