pcol-66
Acrobat X (CS 5.5 Mac OS 10.6) crashes when opening properties
Apr 16, 2012 6:13 AM
Hello,
When I open the properties in Acrobat X (10.1.3) Acrobat crashes.
I have this problem with al of my documents.
I already uninstalled Acrobat and installed it again, but I still have this problem.
I think the problem is in this sector (line 0), but I don't know what I can do about it.
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   ???                               0x02b0f7d7 0 + 45152215
1   com.adobe.Acrobat.framework       0x0018acb1 RunAcrobat + 1553940
2   com.adobe.Acrobat.framework       0x0018ab1f RunAcrobat + 1553538
3   com.adobe.Acrobat.framework       0x00189dc2 RunAcrobat + 1550117
4   com.adobe.Acrobat.framework       0x000a04d8 RunAcrobat + 593467
5   com.adobe.Acrobat.framework       0x000a0098 RunAcrobat + 592379
6   com.adobe.Acrobat.framework       0x000a2089 RunAcrobat + 600556
7   com.adobe.Acrobat.framework       0x000a1d24 RunAcrobat + 599687
8   com.adobe.Acrobat.framework       0x000a05e1 RunAcrobat + 593732
9   com.adobe.Acrobat.framework       0x000a0098 RunAcrobat + 592379
10  com.adobe.Acrobat.framework       0x000a2089 RunAcrobat + 600556
11  com.adobe.Acrobat.framework       0x000a1d24 RunAcrobat + 599687
12  com.adobe.Acrobat.framework       0x000a05e1 RunAcrobat + 593732
13  com.adobe.Acrobat.framework       0x000a0098 RunAcrobat + 592379
14  com.adobe.Acrobat.framework       0x0009fe4c RunAcrobat + 591791
15  com.adobe.Acrobat.framework       0x0009f484 RunAcrobat + 589287
16  com.apple.AppKit                  0x964856f1 -[NSView _drawRect:clip:] + 3721
17  com.apple.AppKit                  0x96482dbd -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 2217
18  com.apple.AppKit                  0x96483750 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 4668
19  com.apple.AppKit                  0x96483750 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 4668
20  com.apple.AppKit                  0x9648234f -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 265
21  com.apple.AppKit                  0x9647ec96 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 3309
22  com.apple.AppKit                  0x963df84b -[NSView displayIfNeeded] + 818
23  com.apple.AppKit                  0x963a8b64 -[NSWindow displayIfNeeded] + 204
24  com.adobe.Acrobat.framework       0x00094db6 RunAcrobat + 546585
25  com.apple.AppKit                  0x963da07e _handleWindowNeedsDisplay + 696
26  com.apple.CoreFoundation          0x99e50dd2 __CFRunLoopDoObservers + 1186
27  com.apple.CoreFoundation          0x99e0cced __CFRunLoopRun + 557
28  com.apple.CoreFoundation          0x99e0c3c4 CFRunLoopRunSpecific + 452
29  com.apple.CoreFoundation          0x99e0c1f1 CFRunLoopRunInMode + 97
30  com.apple.HIToolbox               0x95131d60 RunCurrentEventLoopInMode + 392
31  com.apple.HIToolbox               0x95131b17 ReceiveNextEventCommon + 354
32  com.apple.HIToolbox               0x9513199c BlockUntilNextEventMatchingListInMode + 81
33  com.apple.AppKit                  0x963b0595 _DPSNextEvent + 847
34  com.apple.AppKit                  0x963afdd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
35  com.apple.AppKit                  0x963721f3 -[NSApplication run] + 821
36  com.adobe.Acrobat.framework       0x0001117f RunAcrobat + 6882
37  com.adobe.Acrobat.framework       0x0000f7d9 RunAcrobat + 316
38  com.adobe.Acrobat.Pro             0x00001e92 main + 94
39  com.adobe.Acrobat.Pro             0x00001e16 start + 54
Thankx for helping.
Greetings,
Peter
    May 2, 2012 1:08 AM   in reply to pcol-66
    Try the following solution, it worked for some users.
    Remove the cache file that contains your old serial number by going to Library > Application Support > Adobe > Adobe PCD > cache. Locate the cache.db file.
    Start the application, re enter your serial !
    -hit.anand
    May 2, 2012 3:46 AM   in reply to pcol-66
    Report all bugs to the official page
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Bugs only described on these forums will not be investigated.
  • David Kastendick
    Apr 7, 2010
    May 3, 2012 5:32 AM   in reply to pcol-66
    Good day Peter,
    Thanks for reporting this to our bug form.
    I might also suggest you try this:
    • Restart your computer
    • Move the files: com.adobe.Acrobat.Pro.plist and com.adobe.Acrobat.Pro_10.0.plist from \Users\<username>\Library\Preferences to your Desktop.
    • Launch Acrobat
    • Try to open the Properties of one of your files.
    Let us know how it goes.
    -David
    May 3, 2012 10:55 AM   in reply to David Kastendick
    I've got the same problem as pcol-66. I tried your suggested solution -- restarted the computer, moved the files (see below), launched Acrobat, tried opening a file -- but no success.
    One thing I noticed: There was no com.adobe.Acrobat.Pro_10.0.plist file in my Library/Preferences. The other file, com.adobe.Acrobat.Pro.plist, was there, but instead of com.adobe.Acrobat.Pro_10.0.plist, all I saw was com.adobe.acrobat.90.sh.plist. I tried moving this file to the Desktop, but all it did was cause Acrobat to crash faster. Putting it back simply took me back to where I was at the beginning: I launch the app, I open a PDF, and within seconds, Acrobat goes down.
    I'm on Mac Snow Leopard, and I got my copy of Acrobat 10 as part of CS Design Premium 5.5.
    May 3, 2012 10:49 PM   in reply to hit.anand
    Removing the cache.db file:
    This worked for me, thanks!
    But just a heads up...it erases ALL your Adobe serial numbers and you will have to re-input them when starting up any Adobe series you may have.
