Problem connecting to comment server from Adobe Reader
Apr 23, 2012 7:34 AM
Tags: #acrobat #acrobat_x #acrobat_x_pro #shared_review
I have recently upgraded to Acrobat Professional X. I generate a shared review using the following steps:
  1. Set the option to Automatically collect comments on my own internal server
2. Set the network loctaion (the same location I have always used)
3. Opt to manually send it later:
4. Pick a name
5. Add reviewers
When the reviewer opens the PDF using Acrobat Reader X they can add comments but can only save the file. It does not connect to the server so they are unable to publish. I even tried opening the file in Reader myself and it doesn't connect.
This was all working with Acrobat X until last week. Was there an update to Acrobat that has screwed this up? The only thing I did on my PC was upgrade my FrameMaker to X so I am thinking at that point Acrobat X updated.
I have tried using the following method but the same problem occurs. You can connect and publish comment with Acrobat X but not Adobe Reader X:
Help!
Nicola
    May 23, 2012 12:44 AM   in reply to NMoriarty
    Will it be possible for you to share one such review file which could not open properly on Reader?
    -Abhilasha
