Importing raw+jpeg
Apr 16, 2012 11:13 AM
I have my camera set to shoot raw+jpeg.  When I import into Lightroom 3.6, is there a way to set the import up so that I only import the raw images?
Thanks.
    Apr 16, 2012 11:31 AM   in reply to krawfo
    Edit your Preferences (General Tab) and make sure the highlighted box is unchecked:
    Apr 16, 2012 8:40 PM   in reply to krawfo
    The setting only has an effect on imports done afterwards, so try a new import and see what happens.
    When you talk about “folder” do you mean he disk-folder, or the LR-folder?  Treating RAW+JPG as a single entity should show only the RAWs in LR but both files will be put into the disk folder, if you are copying/moving from somewhere else into the final disk-folder destination.
    If you have more questions, you might be more specific about your import process and the version of LR you are using.  Some have said their combined RAW+JPG import is only showing JPGs when they are finished, using one of the recent or current beta versions of LR.
    Apr 17, 2012 3:45 AM   in reply to krawfo
    krawfo wrote:
    Even though the TREAT JPEG FILES NEXT TO RAW FILES AS SEPARATE PHOTOS box is not checked, the jpegs are still copied to my hard drive.  Maybe the easiest thing would be to delete the jpegs from the CF card before import.
    The option "Treat JPEG files as separate photos" has to be checked! Thus both JPG and RAW files will show up in the import selection screen. However you'll need to de-select the JPG files manually before running the import process, which is still not very comfortable, since afaik files cannot be selected/sorted by file type
    If you don't need the JPG at all, why don't you set your camera to save only RAW files? In terms of file handling this is the easiest way to save time, effort and storage space.
    P.S.: while Jim recommended to uncheck the option, this most likely doesn't solve your problem. It makes LR treat JPGs as a sidecar file of the RAW file, so they are not visible inside LR but of course they still exist in the file system just like the 'real' sidecars files of type XMP.
    Apr 17, 2012 6:45 AM   in reply to krawfo
    You cannot copy only the RAW files during import if you have both RAW+JPG on your CF card.
    You can import everything into LR (with RAW+JPG as SEPARATE FILES) and then use the filter-bar (\ key in Library), adding File Type to the set of filters and clicking on JPG to reveal only those and then selecting them all and right-click-Delete Photos… (From Disk not only Remove from catalog), then setting the Filter back to All File Types.
    You can delete the photos from your CF card before the import process.
    You can switch your camera to RAW-only so you don’t get the JPGs to start with.  What is your reason for shooting RAW+JPG then only caring about the RAWs?
    Apr 17, 2012 7:23 AM   in reply to ssprengel
    Well, this may be an improvement in LR4 then. I never had a LR 3.6 version. In LR4 on the Import screen you can manually choose files to be imported by ticking a checkbox underneath the respective thumbnail (or leave the JPGs unchecked), provided that the option 'Treat JPEG files as separate files' is switched on. Otherwise the JPEG files wouldn't show up on the Import screen.
    Apr 17, 2012 9:39 AM   in reply to Guenther Blumenstock
    LR3 and 4 have the same sort of Import panel with checkboxes by each image.  If you have only a few this is ok.  If you have hundreds you’d have to click things individually, one-by-one.
