v_for_vicious
premiere wont use only small RAM size???
Apr 17, 2012 2:21 PM
i have a very good computer
16gb ram
cpu i7 2nd generation
2tb hdd
ati 6970 graphic card
win7 sp1 64bit
premiere cs5.5
yet the premiere would take only 3gb of ram (when i render or export movies, and using premiere or encoder the same results)..........is there any settings ive missed or what is the case??
also i have another pc(same as above but with i3 cpu and sata2 ssd hdd) and it still take up only 3gb
grateful for any help
    Apr 17, 2012 5:12 PM   in reply to v_for_vicious
    Reset the useage under Preferences, allocate to either Performance or Memory, have you upgraded to CS5.5.2 I only have 12Gb ram and have no problems with HDV or H.264 mov @ 1920 x 1080p  PAL. I have allocated 8GB Ram to performance and use the Mercury Engine with Nvidia Quadro FX3800 in Raid set up., in a Quad Core i7 it is very fast.
    Good luck
    ps. Check your performance with i7 built in Monitor, Windows Task Master, it will give you CPU usage and Physical memory usage, if it is not using the memory allocated check with your computer company ?
    Apr 17, 2012 5:08 PM   in reply to v_for_vicious
    PP will use as much as it needs.
    Apr 18, 2012 5:26 PM   in reply to v_for_vicious
    I would run the PrPro Benchmark test, to see if you have any bottlenecks in the system.
    Apr 20, 2012 8:30 PM   in reply to Jim Simon
    As Jim says, there is no reason to think that Premiere Pro should be using all of your memory all of the time. For many operations, the limiting factor is not memory, and no more than a few gigabytes are needed.
