ripleyrm2
Hierarchical keywords via exif data
Apr 17, 2012 2:25 PM
I am trying to import plant photos into Lightroom4 with their Family, Genus and Species along with Location keywords, by placing the data in the image using exiftool. But failing. One hierarchy seems to work, but not more. I can replicate what Lightroom creates, but it does not seem to read OK.
    Apr 17, 2012 9:19 PM   in reply to ripleyrm2
    Can you provide the exact Exiftool command line that's not working?
    Apr 18, 2012 9:09 AM   in reply to ripleyrm2
    I think you're encountered two issues that aren't very well documented:
    - You need to set the Subject field, not HierarchicalSubject, with the keywords of the form "Big|Small" and leave HierarchicalSubject blank.  LR will properly interpret on import the "|" character in the Subject field.  (LR will only interpret "Big|Small" in HierarchicalSubject if Subject also contains "Big, Small".)
    - You need to provide the -sep option to Exiftool when reading a CSV file:
    Note that there is a space after the comma.  The Exiftool command-line documentation says that is the default for the -sep option, but it doen't appear to be the case.
    Apr 23, 2012 10:13 AM   in reply to John R. Ellis
    The documentation states that ", " is the default for reading.  The default for writing is to not split the value, but I admit this isn't perfectly clear.
    - Phil
