Spry.widget issue in IE
Apr 17, 2012 11:21 PM
Hello,
Pls have a look at http aeonit[dot]name/audi_youtube/index[dot]php
i have used tabs at left bottom side but i also used scrollbar for the tab content. so i have added an ID to li as follow:
<ul class="TabbedPanelsTabGroup">
                <li class="TabbedPanelsTab" tabindex="0"><span id="first_tab">All</span></li>
                <li class="TabbedPanelsTab" tabindex="0"><span id="second_tab">Official</span></li>
                <li class="TabbedPanelsTab" tabindex="0"><span id="third_tab">Fans</span></li>
              </ul>
and the js is
var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1");
$(document).ready(function(){
                //first tab
                    $("#first_tab").click(function(){
                        $('#scrollbar_comment').tinyscrollbar();
                        //alert('hi');
                    //second tab
                    $("#second_tab").click(function(){
                        $('#scrollbar_comment1').tinyscrollbar();
                        //alert('hi');
                        //third tab
                        $("#third_tab").click(function(){
                        $('#scrollbar_comment2').tinyscrollbar();
                        //alert('hi');
</script>
So, The function is working perfect in all browser except IE(Double click works there). So can i add function in spry widget on tab click?
Thnx....
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 18, 2012 12:45 AM   in reply to mahendra rajeshirke
    What version of Spry have you used? And is your CSS version 2.0 or 3.0?
    Oct 15, 2010
    Apr 18, 2012 9:07 AM   in reply to mahendra rajeshirke
    mahendra rajeshirke wrote:
    i am using version 0.7 - Spry Pre-Release 1.6.1
    There is no CSS 0.7. Where are you getting your version numbers from?
