mikeavery333123
Why is the name not being displayed?
Apr 17, 2012 10:14 PM
I am trying to display the firstname from my mysql database after someone has logged in. It was working earlier but my login seemed to only be working 50% of the time. It now works 100% but does not display a name like "Welcome, Mike" like I want it to, it just says "Welcome, "
Any help would be great.
<<<<<<<<<CODE>>>>>>>>
<li style="color:white;">Welcome,
                                                            <?php
                        // Connect to database server
                        include_once '../../mysql_server/connect_to_mysql.php';
                                                            error_reporting(E_ALL);
                                                            ini_set('display_errors', '1');
                              $id = isset($_SESSION['id']);
                        // SQL query
                        $strSQL = "SELECT * FROM myMembers WHERE ID = '$id'";
                        // Execute the query (the recordset $rs contains the result)
                        $rs = mysql_query($strSQL);
                        // Loop the recordset $rs
                        // Each row will be made into an array ($row) using mysql_fetch_array
                        while($row = mysql_fetch_array($rs)) {
                           // Write the value of the column FirstName (which is now in the array $row)
                         echo $row['firstname'];
                        // Close the database connection
                        mysql_close();
                </li>
                <li><a href="../../logout.php">Logout</a></li>
<<<<<<CODE>>>>>>>>>
    Apr 18, 2012 7:05 AM   in reply to mikeavery333123
    This tells me that there is or is not a value for $_SESSION['id'], it returns true or false but not the value of the session.
    Gramps
