Mocha
Apr 18, 2012 4:54 AM
When I paste the records generated in mocha in AE, the image loses the anchor point reference? The image is always moved away from the central point. Thanks
    Apr 18, 2012 5:17 AM   in reply to RB2005
    Same as your other post: Explain properly what you are doing/ trying to do.
    Mylenium
    Apr 18, 2012 7:13 AM   in reply to RB2005
    I'm still not clear what you are saying. Any tracking process produces coordinates relative to the layer, even in mocha. If something drifts, then the most common problem is that you misinterpreted framerates, fields or pixel aspect ratios in either one of the two applications. also keep in mind that mocha always assumes that the layer to use in teh corner pin matches the project size, so if you are uisng a differently sized image, things will not line up.
    Mylenium
    Apr 20, 2012 3:56 PM   in reply to RB2005
    There's a dedicated support forum for mocha. See this:
    http://forums.adobe.com/thread/889993
