wolf_alex3
How to arrange files in the files window?
Apr 18, 2012 12:46 PM
Hello,
I just finished doing the cut of a movie in Premiere Pro and hit the the "edit in Audition" button to do the music and audio. And now the problem: when Audition opened I just saw the hundreds of audio files in the file window (2 for every scene) and until now I didn't find out any possibility to arrange them in subfolders or anything else like you do it in AE or Premiere.
So right now Audition is more or less useless as I have to spend minutes to find my music files within the other files...
Thanks for any proposals...
    Apr 18, 2012 1:52 PM   in reply to wolf_alex3
    What option did you use to send your files over?  There's two "paradigms" for editing in Audition from within Premiere.  The first is editing of specific assets or clips.  In this case, you select one or more clips and choose Edit > Edit in Adobe Audition > Edit Clip which will perform a render & replace operation, then open the new, linked files in Audition.  Any change you make to these files in Audition will be reflected in the corresponding Premiere clip.  This is generally the mode used when you want to perform Noise Reduction or add effects to specific clips.
    The other paradigm is editing the entirety of the sequence.  This method creates a new session in Audition that mirrors your current Premiere timeline, even rendering a preview video.  Here, you can apply edits to any clip in the timeline within Audition, re-record portions, add new audio, and mix and master the session, sending back rendered stems to Premiere.
    Audition doesn't emulate the "project" format of Premiere, so the Files panel is less of an organizational tool than a collection of the raw assets in a timeline.  We are exploring how the "bin" concept that Pr and AE use might be applied, but historically there is a definite distinction between the two workflows.
