• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
why can't I jump to the current slide this time?
Participant ,
Apr 19, 2012 Apr 19, 2012
I am using Adobe captivate 5.5. I have a series of actions on a slide, and I wish that they could be replayed if the learner hits the "replay" button. In order to do this, I want to assign the action of Jume to slide (the current slide) to the "replay" button, so that the playhead can be reset to the beginning of the slide and everything can start over. However, the list of slides for this replay button doesn't include the current slide. I remember doing this in another situation and it worked fine.
Can anyone tell me why I can't jump to the current slide this time?
Views
809
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Apr 19, 2012 Apr 19, 2012
I just checked the project I did before where I was able to jump to the currect slide. It turned out that: if you directly assign the button to jump to slide on the properties panel, it won't include the current slide on the slide list; however, if you assign an "advanced actions", and add "jump to slide" in that advanced action script, then the current slide will be available in the slide list. Very interesting.
Votes
Translate
Translate
Community Expert ,
You are correct that the default list of slides available to jump to does not include the current slide.  If you remember doing this before, it may have been in a different authoring application.
If you want to replay the current slide from the beginning, there are ways to do it using variables and advanced actions.  But the only way you'll be able to change the default behaviour of the Replay button on the playback bar is by using ActionSript 3 coding.
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Votes
Translate
Translate
Report
Report
Community Expert ,
If you want the solution with advanced actions, that Rod is pointing at, watch my blog post about micro-navigation:
Micro-navigation in Captivate
Lilybiri
Votes
Translate
Translate
Report
Report
Resources
Help resources
