PHBIII
Field Numbers are Annoying
Apr 19, 2012 12:52 PM
We are using Acrobat Pro X and are haveing problems with Forms, when the form is opened and filled in there is a field number that obsures the content of the field.  Is there a way to remove these numbers from the form or a way to set Acrobat Pro X to not display the numbers on a form field.  We do not see this problem when using Adobe Reader 10.5
  • Randy Swineford
    Mar 7, 2011
    Apr 19, 2012 12:55 PM   in reply to PHBIII
    This forum is for the Adobe FormsCentral (formscentral.adobe.com) which is a service that allows you to create, collect and analyze data using an online web form. You should ask PDF related form questions in the Acrobat forums: http://forums.adobe.com/community/acrobat/forms
    I'll move your post to that forum so you don't need to retype it. They can help you out...
    Randy
  • George Johnson
    Aug 11, 2002
    Apr 19, 2012 1:02 PM   in reply to PHBIII
    What tool do you have selected? It looks like the numbers that get displayed when the TouchUp Reading Order tool is active or the Order navigation panel is selected.
  • George Johnson
    Aug 11, 2002
    Apr 19, 2012 1:31 PM   in reply to PHBIII
    Is the Order pane that's to the left of the page open?
    If not, waht happens if you open and then close it?
  • George Johnson
    Aug 11, 2002
    Apr 19, 2012 1:56 PM   in reply to PHBIII
    I'd be interested in taking a look at the actual form if you're free to send it to me at: acroscript at gmail dot com
