Hi, I'm using Flash CS5 and actionscript 3 and going through a "bouncing ball" tutorial from a book that I bought.
The ball is supposed to bounce around a window indefinately.
The example works but instead of the ball keeping within the boundaries of the window it floats off the screen never to return.
Can someone please have a look at the code below and tell me what I can add to make this work as described?
Thank you very much.
package {
//Import necessary classes
import flash.display.MovieClip;
import flash.events.Event;
import flash.geom.ColorTransform;
import flash.geom.Rectangle;
public class Ball extends MovieClip {
//Horizontal speed and direction
public var speedX:int = 10;
//Vertical speed and direction
public var speedY:int = -10;
//Constructor
public function Ball() {
addEventListener(Event.ENTER_FRAME, onEnterFrame);
//Colors the ball a random color
var colorTransform:ColorTransform = new ColorTransform();
colorTransform.color = Math.random()*0xffffff;
transform.colorTransform = colorTransform;
//called every frame
private function onEnterFrame(event:Event):void{
//Move ball by appropriate amount
x += speedX;
y += speedY;
//Get boundary
var bounds:Rectangle = getBounds(parent);
//Reverse
//of stage.
if (bounds.left < 0 || bounds.right > stage.stageWidth) {
speedX *= -1;
It looks like you do not have anything to keep the ball within the boundaries for the y side of the story, only the x. You need to have something for speedY just like you do for speedX where you check the bounds.top and bounds.bottom...
if (bounds.top < 0 || bounds.bottom > stage.stageHeight) {
speedY *= -1;
