Error: Can't install CS6 PS , Exit Code:6, Error: DW050
Apr 20, 2012 7:17 AM
Tags: #error #bug #install #cs6 #bug_report #cs6_beta #photoshop_cs6_beta #installer_crash
Hey i'm running an mac(intel) with OS x 10.7 Lion on it.
Everytime I tryed to install CS 6 Photoshop the installer froze.
I cleaned my mac with the cs cleaner tool and tryed to install Photoshop in security mode but following error occurred:
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 35 error(s), 0 warning(s)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Linguistics CS6: Install failed
ERROR: DW050:  - Dynamic Link Media Server: Install failed
ERROR: DW050:  - AdobeColorCommonSetCMYK CS6: Install failed
ERROR: DW050:  - Adobe XMP Panels: Install failed
ERROR: DW050:  - Suite Shared Configuration CS6: Install failed
ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
ERROR: DW050:  - AdobeColorJA CS6: Install failed
ERROR: DW050:  - Required Common Fonts Installation: Install failed
ERROR: DW050:  - PDF Settings CS6: Install failed
ERROR: DW050:  - AdobeColorPhotoshop CS6: Install failed
ERROR: DW050:  - Adobe Utilities CS6: Install failed
ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050:  - AdobeColorEU CS6: Install failed
ERROR: DW050:  - Camera Profiles Installer: Install failed
ERROR: DW050:  - AdobePDFL CS6: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesCS CS6: Install failed
ERROR: DW050:  - PDF Settings CS5: Install failed
ERROR: DW050:  - Adobe ExtendScript Toolkit CS6: Install failed
ERROR: DW050:  - AdobeTypeSupport CS6: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Support: Install failed
ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS6: Install failed
ERROR: DW050:  - Adobe Mini Bridge CS6: Install failed
ERROR: DW050:  - AdobeColorNA CS6: Install failed
ERROR: DW050:  - AdobeColorCommonSetRGB CS6: Install failed
ERROR: DW050:  - Photoshop Camera Raw 7: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
ERROR: DW050:  - DynamiclinkSupport: Install failed
ERROR: DW050:  - AdobeCMaps CS6: Install failed
ERROR: DW050:  - Adobe CSXS Extensions CS6: Install failed
ERROR: DW050:  - Adobe Bridge CS6: Install failed
ERROR: DW050:  - Adobe CSXS Infrastructure CS6: Install failed
Do you have any ideas?
    Apr 20, 2012 1:16 PM   in reply to Georges1990
    Try following the below mentioned steps:
    1) Reboot your system
    2) Re-download the installer, Unzip the installer using winzip or winrar
    3) Run the the set-up.exe by using clicking on the right mouse button and choosing Run As Administrator.
    If that doesn't work -- come back here to the forums and I'll get more engineers involved with this.
    thanks!
    Apr 20, 2012 11:44 PM   in reply to Pete.Green
    On Windows 7, 64 bit, with the Beta 64 bit version of Photoshop CS6...
    I got this error after installation (20th of April):
    ERROR: DW050:  - Microsoft Visual C++ 2008 Redistributable Package (x64): Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2008 Redistributable Package (x86): Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2010 Redistributable Package (x64): Install failed
    ERROR: DW050:  - Microsoft Visual C++ 2010 Redistributable Package (x86): Install failed
    I followed the advice to run the set-up.ex "as admin" - but same problem.
    If I load these packages from Microsoft - the installation is interrupted at once with a certificate-error.
    This problem (I guess) causes the following error message to promt again and again while I wirte this: "CS6 Servide Manager.exe: The program could not start correctly (0xc000007b), Click Ok to close the program."
    Best regards,
    Eigil
    21st of April:
    ..and this new error is received, even before CS6 is started on the computer: "CS6 Service Manager.exe: The program cannot be started, as MSVCP100.dll is missing on the computer. Try to reinstall to solve the problem."
    (have tried to reinstall - same problem).
    These problems are severe, as they are interrupting all tests and (even the writing in this forum, i.e. the message returns each 10th-30th second demanding an OK to be cleared).
    Apr 24, 2012 6:27 AM   in reply to Eigil Skovgaard
    Hi Eigil,
    It seems Microsoft VC redist package was corrupted on your system.
    This is a third part issues, Please install it from the following link:
    http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=15 336
    http://www.microsoft.com/download/en/details.aspx?id=29
    Please re-install Ps after installing these packages and running Windows Update..
    Do let us know if you still face any issue.
    Regards,
    Ashutosh
    Apr 24, 2012 6:31 AM   in reply to Georges1990
    George that was for Eigil.
    Please send me installer logs at asnigam@adobe.com
    You  can find them at Library/Logs
    Regards,
    Ashutosh
    Apr 24, 2012 7:56 AM   in reply to Ashutosh.Nigam
    Hi Ashutosh,
    Sorry for the late answer - I have been busy.
    I have lost faith in this beta version, so I have not made a reinstall - after I had to recover my computer entirely. Not CS6's fault, but this and that harmed the Win registry so badly, that at last everything was "forbidden" and corrupted.
    I am looking forward to a more stabil version - i.e. not a beta ;O)
    Sorry to be such a chicken, but my business data are more important to me.
    Best regards,
    Eigil
    May 1, 2012 10:00 AM   in reply to Georges1990
    Has anyone found a way to successfully resolve the exit code on Mac?
    May 1, 2012 11:22 AM   in reply to buffalo_tom
    Buffalo_tom,
    There have been different resolutions for different exit code errors -- so if you're having one -- start a separate discussion thread and we'll be able to work with you on it.
    Cheers,
    Pete
