1richard1
making play button to play different clips
Apr 21, 2012 9:04 AM
Tags: #problem #cs5 #flash #script #button #code_snippets #action_script_3 #movieclip #ac3 #actionscript3 #function #actionscript_3.0
how do i make a play button play different movie clips that are placed on to a timeline in actionscript 3?
here is an example of what im doing. so you drag and drop the moive clips on to the timeline, at the bottom which then snaps in to place.
once the timeline has been filed up you press the play button, then it plays all the moive clips in sequence.
  • kglad
    Jul 21, 2002
    Apr 21, 2012 9:04 AM   in reply to 1richard1
    you assign instance names to each movieclip and button (in the properties panel) and in the actions panel you assign listeners to your buttons that call a listener function that "plays" your movieclip.  for example, if you have a button (btn1) and movieclip (mc1), you could use:
    btn1.addEventListener(MouseEvent.CLICK,btn1F);
    function btn1F(e:MouseEvent):void{
    mc1.play();
  • kglad
    Jul 21, 2002
    Apr 21, 2012 12:23 PM   in reply to 1richard1
    copy and paste the code you tried.
  • kglad
    Jul 21, 2002
    Apr 21, 2012 3:08 PM   in reply to 1richard1
    does this part of your code work:
    play_btn.addEventListener(MouseEvent.CLICK, fl_Click_Play);
    function fl_Click_Play(event:MouseEvent):void
        MovieClip(this.parent).play();
  • kglad
    Jul 21, 2002
    Apr 22, 2012 6:43 AM   in reply to 1richard1
    if you're trying to get the main timeline to play with that code, use:
       MovieClip(this.root).play();
  • kglad
    Jul 21, 2002
    Apr 22, 2012 7:11 PM   in reply to 1richard1
    if you have a number of movieclips on the main timeline that you want to play, you can assign them to an array and loop through the array to play them.  if you want all the movieclips on the main timeline to play, you can use:
    playAll(MovieClip(root));
    function playAll(mc.MovieClip):void{
    for(var i:int=0;i<mc.numChildren;i++){
    if(mc.getChildAt(i) is MovieClip){
    MovieClip(mc.getChildAt(i)).play();
  • kglad
    Jul 21, 2002
    Apr 23, 2012 3:10 AM   in reply to 1richard1
    did that last answer resolve your  "making play button to play different clips" issue?
    if so, mark that answer as correct and start a new thread for new issues.
